I have noticed that the feed rate when running a job is around 10% of what the gcode set so I had a look into the CV setting which took a while and a bit of reading of old posts in the forum but I think I have now got it switching between CV and ES mode the way it should. But the feed rate is not showing what was requested, for example when I enter a simple move in MDI, G1 X300 F1000 the FRO shows 973. When I run the following gcode
G1 X0 Y0 F1000
G1 X100
G1 Y100
G1 X0 Y0
M30
The FRO shows a feed rate of 937 for lines 1 -3 and 2930 for the return to X0 Y0. It seems to do this in both CV and ES mode.
I have tried this in Mack3.42.40 and it all goes as it should. I then tried it with the the 1024 screen on Mach3.43.19 and observed the same error I had with MSM beta 5 and Mach3.43.19. Looks like a bug in this version of Mach or something corrupt in my XML, can anyone confirm this one way or another please?
Calum
