May 26, 2012, 08:20:08 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Galil (Moderators: smurph, kcrouch)
| | |-+  how do i find the plugin config screen like in the manual.
Pages: 1   Go Down
Print
Author Topic: how do i find the plugin config screen like in the manual.  (Read 431 times)
capsteve
Active Member
Offline Offline
View Profile
« on: August 21, 2010, 12:50:17 PM »
Fresh install of XP. Wdsk32 running smoothly. I can choose the Galil plugin during the startup of
mach3, but It doesn't see the Galil 1842. I don't see a dropdown like shown in the manual to choose
The card.....
Also does anyone know if mach3 will run a contec 16 I/O board......
kcrouch
Active Member
Offline Offline
In way too deep!!!
View Profile
« Reply #1 on: August 21, 2010, 01:25:57 PM »
The screen you are looking for is under config>config plugins.
Select the Galil plugin and you will get the screens as in the PDF manual.
Kenny
Having way too much fun! Something must surely be wrong.
capsteve
Active Member
Offline Offline
View Profile
« Reply #2 on: August 21, 2010, 04:25:31 PM »
There it is......thanks.
steve
Pages: 1   Go Up
Print
Jump to:
