February 13, 2012, 05:29:34 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  How to ignore macros (M calls) in Run from here mode?
Pages: 1   Go Down
Print
Author Topic: How to ignore macros (M calls) in Run from here mode?  (Read 341 times)
lfleiva
Active Member
Offline Offline
View Profile
« on: August 18, 2010, 12:58:48 PM »
Hi!
In general config there is an option for Ignoring M calls while loading program which works great.
But Mach still runs M code macros when simulating in "run from here".
Anyone knows how to disable the macros in this case?
Thanks!
Luis fdo.
zealous
Active Member
Offline Offline
View Profile WWW
« Reply #1 on: August 19, 2010, 02:17:49 PM »
One way is to set a UserLED when the user presses the RFH and reset the LED when they press the start and in your macro's check the state of the LED.
The "Estimating LED" LED18 will be active while it processing the RFH...so you could possiable use that LED.
Regards, Jason Blake
www.Fusioncnc.com
lfleiva
Active Member
Offline Offline
View Profile
« Reply #2 on: August 23, 2010, 05:23:02 PM »
Used a UserLED.
Worked fine.
Luis
Pages: 1   Go Up
Print
Jump to:
