Hello Guest it is June 12, 2026, 01:43:34 PM
Author Topic: Buttons that execute g-codes  (Read 22575 times)
« on: August 17, 2010, 04:10:35 PM »
I am desigining a screen with several buttons that will execute G0 codes for rapid linear motion. However, I cannot get my CNC motors to move rapidly, amd it behaves the same as G1 and it is determined by the feed rate.
When I enter G0 manually in the MDI, or run a text file containing G0, it works in both cases.
Any help on this issue would be very much appreciated.
I am using MachScreen V 1.43.3
« Last Edit: August 17, 2010, 04:14:06 PM by tj1988 »
Re: Buttons that execute g-codes
« Reply #1 on: August 17, 2010, 05:29:07 PM »
You didn't say how you've configured the buttons??
« Reply #2 on: August 17, 2010, 05:52:41 PM »
Hi Gerry,
The button simply executes a G-code, G0Z.5G1X.5. I want the Z to travel with rapid position (G0) and the X to travel with linear motion at feed rate (G1).
I'm sorry if i'm not being clearer, I'm new to this!
Thanks again.
« Reply #3 on: August 17, 2010, 07:15:23 PM »
You can't have G0 and G1 on the same line. Move the Z first, then the X.
G0 Z0.5
G1 X1.5
« Reply #4 on: August 17, 2010, 08:59:18 PM »
Thank you!
