May 26, 2012, 06:39:16 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  LazyCam
Pages: 1   Go Down
Print
Author Topic: LazyCam  (Read 454 times)
Skyhawk
Active Member
Offline Offline
View Profile
« on: August 10, 2010, 05:48:00 PM »
We are still deciding on what control software to use but Lazycam is looking good for the g code.  Is it possible to just purchase Lazycam pro as a stand alone package?
Global Moderator
Offline Offline
View Profile
« Reply #1 on: August 10, 2010, 09:05:11 PM »
Yes, LazyCam will post the gcode to a text file and can be run standalone. You should try LC and see if is the right software for you / your use and there are others out there which you should try, and then the choice is yours. Have a look at the last page ( 122 ) in the LazyCam Manual
What control software you use is again a decision that you must make.  There certainly are a lot of users that think it's the best around. Wink
Skyhawk
Active Member
Offline Offline
View Profile
« Reply #2 on: August 11, 2010, 06:22:03 AM »
Thank you Rich!
I downloaded Lazycam and it seems to be what I am looking for but I am still having one problem.  For things like cutting outlines, pockets, and other 2d items, I seem to be doing just fine.  However, I can't seem to figure out how to have the CAM software(s) to fillet, chamfer, or other tapper operations.
Example:
Not the only thing we need to do but when I create a guitar body in 2d and make the pockets that seems to work fine.  But I seem to be limited to flat surfaces.  I want to be able to have curved faces such as Les Paul guitars.  This is just an example though.
Another example would be a city scene with raised/ curved faces.
When I try to make it in Autocad and save it as a DXF it wont import.  It says no entities found.
Here is another video example of what we need to be able to do.
http://www.youtube.com/watch?v=uI70AjVbKbQ
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #3 on: August 11, 2010, 10:53:10 AM »
You need a 3D CAM program. Loot at MeshCAM, or Vectric's Cut3D. You might also want to look at Vectric's Cut2D, which is far superior to LazyCAM imo.
Skyhawk
Active Member
Offline Offline
View Profile
« Reply #4 on: August 11, 2010, 01:44:17 PM »
Thank you, I will check them out.  I like the look of MeshCAM but I'm not looking forward to dropping the cash.  Not that it is that bad compared to some I have been looking at.
Why doesn't LazyCAM do more 3d objects?
Global Moderator
Offline Offline
View Profile
« Reply #5 on: August 11, 2010, 04:20:08 PM »
Only good for 2D, so as Gerry suggested, you need get a more advanced software than LC for what you want to do.
LC development was stopped some time ago. Back to "dropping the cash" my friend...........
Pages: 1   Go Up
Print
Jump to:
