Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 06:18:14 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Galil
(Moderators:
smurph
kcrouch
Possible bugs in MachStandardMill or R3.043.012 when used with Galil plug-in.
Pages:
1
Go Down
« previous
next »
Author
Topic: Possible bugs in MachStandardMill or R3.043.012 when used with Galil plug-in. (Read 609 times)
jj83002
Active Member
Offline
on:
August 09, 2010, 11:47:30 AM »
I'm not sure how many of you are running the development version of Mach3 with MachStdMill, but there appears to be a few bugs in it. Previously, I was running Mach3 R3.042.040 with the Galil plug-in and it worked very slick. However, I really like the new MachStdMill screen set and thought I'd give it a try. I found the following bugs:
1. If I enter any command in the MDI window, it does a cycle start. This is very scary if a program is loaded. The program starts and the machine takes off. I installed a clean version of MSM and R3.043.012 on another computer and it also flashes the cycle start button when a command is entered in MDI.
2. After finding this, I made sure there was no program loaded and entered the spindle command string M3 S1500 in MDI. This will start the spindle at the correct speed and direction, but the spindle stops after about one second. I can manually start the spindle with the CW or CCW buttons.
3. When I run an edge finder to verify my vice location at offset G54, Mach3 forgets its absolute position, the softlimits are no longer accurate, and it is easy to run the machine into a limit switch.
4. One really weird problem is if I run the NewFangled linear hole pattern wizard: the X, Y, incremental, and angle input windows display unstable numbers. I believe the other wizards function normally.
I did not find any of these problems with the standard Mach3 R3.042.040.
Having said all the above, I think the MSM screen set is very nice and I like its logical set-up. If I can help anyway in testing solutions to the above, please let me know.
Jim
smurph
Active Member
Offline
Re: Possible bugs in MachStandardMill or R3.043.012 when used with Galil plug-in.
Reply #1 on:
August 10, 2010, 08:59:15 PM »
The Galil Plugin only follows what Mach tells it to do. Try a profile with the old screen and R3.043.012
smurph
Active Member
Offline
Reply #2 on:
August 10, 2010, 09:08:25 PM »
I just checked the MDI on MSM and it does do a cycle start. Why? Because the cycle start button has focus and when you hit enter for the MDI command, then that act also activates cycle start. It's a MSM bug.
Using the same version of Mach and the old standard screen works as expected.
Last Edit: August 10, 2010, 09:10:17 PM by smurph
battwell
Active Member
Offline
Reply #3 on:
August 27, 2010, 03:55:36 PM »
that was an interesting read thanks.
il leave msm for a while until the bugs are ironed out then!
by the way. thanks smurph for sorting out the reversing of extended i/o on galil pluging (im the one using all 64!)
if its not broken yet, fit more gadgets!
smurph
Active Member
Offline
Reply #4 on:
August 27, 2010, 04:43:28 PM »
I'm glad that got the ext. I/O working for you.
Also, that MSM bug is gone with 043.019
Steve
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
