Hello Guest it is June 09, 2026, 01:37:59 AM
Author Topic: Chances of Closed loop?  (Read 51343 times)
« on: August 06, 2010, 01:31:40 PM »
I just learned for the first time today that Mach3 was not a closed loop system.  I started out my CNC build journey on CNC Zone and could swear I learned that encoders would tell Mach3 the true position and Mach3 would use that to keep the cutter in the right path.  It's been a sad day for me. :)  I have been working on my machine for years and am close to added encoders.  (up till now to do just what I said).  I will still add the encoders but wondered when if at all this might become an feature of our beloved program?
E
Offline rcaffin
  •  1,073 1,073
Re: Chances of Closed loop?
« Reply #1 on: August 07, 2010, 12:10:00 AM »
This is normally handled in the servo controller. Mach tells the servo SYSTEM to move 1". It is up to the servo system to make sure it does move 1". Proper servo controllers do this of course.
Note: stepper motor controllers can be open loop and not ensure this.
cheers
« Reply #2 on: August 07, 2010, 07:35:31 AM »
But why cant the software do this.  It would be a great improvement to an already amazing program.  Remember the better our tools get, to better we get.  Most of us don't use servos and having software that would add one more level of accuracy to our builds narrows that gap ever so slightly between us and the pros.
Evan
« Reply #3 on: August 07, 2010, 08:08:05 AM »
If you're using steppers, closed loop won't help you. If you are out of position with a servo, more power is applied to get back to  position. If you're out of position with a stepper, it's because it didn't have enough power to begin with, and there isn't any more available to get back to position. The only way it would work would be to slow all the axis down until the out of position axis gets back to position.
But I think an even more important issue is that it would probably require a completely new version of Mach3 to implement it, and that's just not going to happen.
There are probably tens of thousands of Mach3 users using steppers who don't need closed loop. A properly designed stepper system will never lose steps or position.
 If you lose steps, you're machine is underpowered. It's as simple as that. Buy the correct motors and drives to give you the performance you want. You don't need closed loop, you need the correct motors and drives to achieve the performance you want.
Offline rcaffin
  •  1,073 1,073
« Reply #4 on: August 07, 2010, 04:46:01 PM »
Let's look at this the other way around. Why SHOULD the software have to do this for 3 -6 axes simultaneously when servo drives are perfectly capable of doing it? All this idea would do is load the CPU more; there would be no significant improvement to the machine operation.
There is also the problem of the amount of I/O traffic involved. You would have to feed the optical encoder signals (for non-steppers) back to the CPU for every axis. That would make the interface enormously more complex - for no gain. Why do that? (Could Windows handle the Real Time load? I doubt it!)
Would transferring the compute load from being distributed across every servo drive into the CPU make the system any better? Nope. We KNOW that the current approach, as used by nearly every CNC machine and robot system out there, works excellently.
To suggest that 'Most of us don't use servos' is actually misleading.  If you don't use servos, what are you using? You would have to be using steppers, and ger21 has already answered that one completely. Increasing the amount of computer power used is NO substitute for having a properly designed and configured hardware system in the first place. That means having motors of the right power.
As far as I know, most stepper systems do NOT provide any feedback to anywhere - unless they have been built with encoders, which seems unlikely here. After all, how is a stepper system going to use the output of an encoder? Either the motor has the torque to step, or it doesn't. So what could a typical stepper system tell the CPU? Nothing. Don't get me wrong: stepper systems are fine - I've used them myself. All I used was a Home flag.
« Reply #5 on: October 02, 2010, 05:14:17 PM »
I have a small 3 axis machine using steppers. Since I need to do fine milling for PCB's I decided to add encoders to each of the steppers
I find that I will drop an occasional step which isn't a big issue, but over the course of milling it can add up, one here, one there etc.
I want to be able to pause Mach3 when I detect I'm missing position, so I can use the external hardware I have to move back to where I should be
Since I would only be a few pulses out of position, hopefully It wont be too apparent.
My question is, how can I pause Mach3 from a digital input, I'm sure it possible
Offline rcaffin
  •  1,073 1,073
« Reply #6 on: October 02, 2010, 06:42:54 PM »
You would be far better off checking the acceleration figures for your steppers, and setting them to something which does not have this problem. Or buy bigger stepper motors.
Have you tried Feed Hold?
« Reply #7 on: October 02, 2010, 10:29:31 PM »
My system has servos. When I command say G0 X500, I see the movement in Machs DRO, but if my driver is off nothing moves physically. That is deceiving. It would be nice if the servo´s encoders pulses could be fed back to Mach and have mach inform if there are differences between what was commanded, and the real movement. This would not be closed loop with Mach. It would just be a way of warning the user if what is really happening differs from what Mach is showing.
Jorge
« Reply #8 on: October 02, 2010, 11:21:54 PM »
Thats basically how my system is now, with the encoders and hardware attached I can tell when I am missing pulses As far as I know mach3 cant use the feedback, so I have 3 lights mounted on my control panel that shows when an axis is out of position. Now I can tell how many steps I've missed, just wish I was able to use this information to correct the position
« Reply #9 on: October 03, 2010, 06:55:21 AM »
You can write a macro pump or plugin to compare the commanded position to the encoder position and pause the machine when they don't match. A plugin comes with this board.
http://rogersmachine.net/encoderinterface.html
