Hello Guest it is June 11, 2026, 01:35:36 PM
Author Topic: PWM and routers?  (Read 19831 times)
Re: PWM and routers?
« Reply #10 on: August 21, 2010, 09:23:11 AM »
Thanks for that tip, however the IJ mode was already set to Inc, I decided to try setting it to Absolute and this solved the problem immediately and all is well without having to run a wizard first.
I will re-read the Machmill manual to try to understand what is going on
aqmsreme
« Reply #11 on: August 21, 2010, 12:06:36 PM »
A lot of the wizards use absolute mode, so when you run a wizard, they changed the IJ mode to absolute, which is apparently what you're using as well. But since you had Mach3 set to incremental, it would revert back whenever you closed and restarted Mach3.
One way to make sure this never happens is to place a G90.1 at the start of your code, which will automatically put Mach3 into Absolute IJ for your code.
