Hello Guest it is June 09, 2026, 02:23:14 AM
Author Topic: Found my problem  (Read 9702 times)
Found my problem
« on: August 02, 2010, 11:38:51 PM »
Quite some time ago I had a hard time getting my machine to run. Some might remember because I got a lot of help from forum members. I finally got it working but I still kept getting intermitent problems. I finally found the problem. I was using the 5volt supply from my computer power supply. It seems that there was a problem with the power supply. The voltage would intermitently drop to around 3 volts. Strangely enough the PC wasn't effected. I added an external supply and have not had a problem since.
Re: Found my problem
« Reply #1 on: August 03, 2010, 08:12:54 AM »
Thanks for posting the info.
It will probably help someone down the road.
Mike
« Reply #2 on: August 03, 2010, 11:40:54 AM »
Just curious about this, was the 5volt supply from a USB jack by any chance?
« Reply #3 on: August 03, 2010, 12:21:46 PM »
No. It was connected to one of the power supply plugs. The cable was 18 ga shielded and about 4 ft. long. Since the PC was unaffected I am thinkng there could have been a minor voltage drop across the cable. The supply I used had a good solid 5v output and I mounted it in the control box with the breakout board.
« Reply #4 on: August 03, 2010, 12:38:31 PM »
I see, thanks for that, I was wondering if possibly the USB voltage dropped as I've actually heard of that happening before on certain PC's.
Glad you figured it out and thanks for posting-
« Reply #5 on: August 04, 2010, 12:42:45 PM »
An XP pc will power down devices to conserve power and sometimes you will need to go into the device manerger to stop it and somtimes the bios also . Win7 seems not to do it as long the power settings are set to high perfomance
glad you got it fixed this sight has helped me a lot also
