May 26, 2012, 05:00:43 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Sizing seems to be a problem!!
Pages: 1   Go Down
Print
Author Topic: Sizing seems to be a problem!!  (Read 567 times)
BOHICAMAN
Active Member
Offline Offline
View Profile
« on: August 02, 2010, 05:26:52 PM »
I have MACH3 (demo) version 3.042.029 installed with a HobbyCNC Pro board hooked to a Sherline 2000 CNC Mill. I also have LazyCam Pro V3.00.2. Here's the problem. I downloaded the LazyCam tutorial drawing (LCRO_HCIR.dxf) used in tutorial #1. After EXACTLY following the tutorial, I posted the G-code to MACH. It appears to run fine - except in minature! The entire machined piece is only about an inch long! This happened before with another drawing. I was meticulous in setting up MACH3 and LazyCam, but obviously I missed something Huh. The are both set for "inches" . Anyone have any suggestions? Thanks!
Bob
"For those who fought for it, Freedom has a flavor the protected will never know"
UNKNOWN
Active Member
Online Online
Carnoustie, Scotland
View Profile
« Reply #1 on: August 02, 2010, 05:35:45 PM »
If you command a move via MDI does it travel that distance. Example, if you zero the X axis then command G0X1 does the X travel one inch?
BOHICAMAN
Active Member
Offline Offline
View Profile
« Reply #2 on: August 02, 2010, 06:21:07 PM »
Hood,
It moved 1/8th inch
UNKNOWN
Active Member
Online Online
View Profile
« Reply #3 on: August 03, 2010, 01:13:12 AM »
Sounds like you need to set your steps per unit correctly.
What pitch ballscrews do you have?
Any gearing between motors and ballscrews?
What microstepping do your drives have?
BOHICAMAN
Active Member
Offline Offline
View Profile
« Reply #4 on: August 03, 2010, 01:23:35 PM »
Hood,
Ballscrew 20 tpi, single start. No gearing between motors and ballscrew. Microstepping setup on board at 1/4inch, motors are #23-305-DS8A 425oz-in bipolar rating, 305oz-unipolar rating, 4.2v, 3A, 200 S/R, 3.2mH, Size #23, Dual Shaft, 8 wire. Hope that provides info you requested.
UNKNOWN
Active Member
Online Online
View Profile
« Reply #5 on: August 03, 2010, 01:34:11 PM »
Ok so
your steppers are 200 steps per rev, Microstepping is 1/4 so you will need 200 x 4 = 800 steps to turn the motor one revolution.
You need 20 turns of the screw to move one inch so steps per unit in motor tuning will be 800 x 20 = 16,000.
BOHICAMAN
Active Member
Offline Offline
View Profile
« Reply #6 on: August 03, 2010, 01:37:59 PM »
Thanks!! Will elt you know how I make out.
UNKNOWN
BOHICAMAN
Active Member
Offline Offline
View Profile
« Reply #7 on: August 03, 2010, 01:57:45 PM »
Hood,
That seemed to fix it! Thanks for the help!!
Bob
UNKNOWN
Active Member
Online Online
View Profile
« Reply #8 on: August 03, 2010, 01:59:27 PM »
No problem Smiley
Pages: 1   Go Up
Print
Jump to:
