Hello Guest it is June 11, 2026, 06:59:19 AM
Author Topic: Homing and limit sensors  (Read 7369 times)
« on: August 01, 2010, 04:22:51 AM »
Hi everione, This week i starting with motor tunig,homing...ect. I have the homing switch and X+ and X- limit switches. When making a ref X, and hiting the limit switch,
for testing the securiti, the axis is stil moving for search home switch. Any Idea how make the limit switches working when Homing? Thank.
Offline Fastest1
  •  920 920
  • Houston, TX
Re: Homing and limit sensors
« Reply #1 on: October 20, 2010, 02:23:03 PM »
Are your home switches enabled in Ports & Pins? (Mine are enabled though I dont have homing swtiches) but I do have 1 limit switch per axis with a ramp at each end acting as 2. All of my limits are connected to the same pin. Looking at your statement again, your homing switch is on a different pin than your limits, right? The machine can not pass a limit switch but can pass a home switch. That is the way I understand it. My home is a software home. I am now wondering why my homing switches are enabled but it works! I wont be changing it.
