May 26, 2012, 04:27:44 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Newest ver 3.42.12 running without cycle start.
Pages: 1   Go Down
Print
Author Topic: Newest ver 3.42.12 running without cycle start.  (Read 669 times)
Mc2
Active Member
Offline Offline
View Profile
« on: July 31, 2010, 08:35:12 AM »
I have loaded the newest ver. of Mach3 and am now having issues. I have tested this on two computers and ruled out the smooth stepper. When I load a program and the go into MDI mode, I type in G0X0, the program starts to run. Not good. Has anyone else had this issue? I guess I will need to install an older ver.
thanks, Jim.
BR549
Active Member
Offline Offline
View Profile
« Reply #1 on: July 31, 2010, 08:59:48 AM »
I can confirm that it does it here as well. Ver 3.43.12
DaveCVI
V4 Screen Contributor
Offline Offline
View Profile WWW
« Reply #2 on: July 31, 2010, 11:56:33 PM »
This was a bug in versions of mach 3.43.x before .10 - we held up the start of MSM beta until the fix was available in 3.43.10.
Am I correct in assuming that you are using the standard 1024 screen set when this happens?
It would be real helpful if you would please see if 3.43.10 does this for you - it's avail form the archive section of the download page.
www.CalypsoVentures.com
Mc2
Active Member
Offline Offline
View Profile
« Reply #3 on: August 01, 2010, 09:10:40 AM »
Dave, I re-installed 3.43.10 as you suggested. I didn't have this issue. I am using the standard screen set. I then put 3.43.12 back on. My issue came back. I then with ver 3.43.12 ran Mach 3 with the new millstadard screen set and I still had this issue.
thanks, Jim.
DaveCVI
Offline Offline
View Profile WWW
« Reply #4 on: August 01, 2010, 11:48:55 AM »
Thanks for the testing.
I'll inform Brian that it appears that the bug has crept back into 3.43.12.
Mc2
Active Member
Offline Offline
View Profile
« Reply #5 on: August 01, 2010, 01:17:19 PM »
Thanks Dave, I will be looking for the updated software and install it when it comes out. I quite often input a value into my dro when I am on the edge of my materials. Then I will command the axis to go to it's zero postion. G0X0 as an exaple.
Jim.
Pages: 1   Go Up
Print
Jump to:
