Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 04:01:29 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
FAQs
Mach 3 Motor Calibration
Pages:
1
Go Down
« previous
next »
Author
Topic: Mach 3 Motor Calibration (Read 2437 times)
neiter13
Active Member
Offline
on:
July 29, 2010, 07:59:11 AM »
I was told to calibrate the motors on my Dyna and I'm not 100% sure on how to do that. i took measurements on the distance it says it traveled and the distance it actually traveled. Now i am stuck. is there somewhere where i put those ratios of those numbers or is there something else completely that i need to do.
Global Moderator
Offline
Re: Mach 3 Motor Calibration
Reply #1 on:
July 29, 2010, 05:16:53 PM »
Steppers or servo motors?
neiter13
Active Member
Offline
Reply #2 on:
July 30, 2010, 08:16:55 AM »
Stepper
Global Moderator
Offline
Reply #3 on:
July 30, 2010, 08:30:30 AM »
From memory so hope the following is correct,
You put a desired moved value in for the axis, Mach reports back and says here how far it moved, if you agree with reported move distance , click yes, then it will ask if you want to save the steps per unit and will change the steps per unit in motor tuning. If the moved value is not what you input, then put that value in and try again. Very quickly Mach will find the steps per unit value which is correct for the movement you wanted.
neiter13
Active Member
Offline
Reply #4 on:
July 30, 2010, 10:21:01 AM »
alright, thanks a lot
Eduardo
Active Member
Offline
Reply #5 on:
September 10, 2010, 11:25:43 PM »
Hi there!
I am following this procedure, however it only moves very small distances. Let me explain this better.
When Mach3 asks me to write how for I would like to move the axis, I am using 100 (in), and the actual movemen.5
t is around 0.5 in. so Mach3 displays 40000. Accepting this parameter, moving the machine 1 unit (g0 x1.0 f50) should be moving the machine exactly 1 unit in the x-direction, However, this is not the case.
What am I doing wrong?
I will appreciate any help to this matter.
Thank You
Global Moderator
Offline
Reply #6 on:
September 11, 2010, 07:45:34 AM »
Eduarado,
Mach will increase or decrease the steps based on actual movement. If your way off in your steps per inch to begin with then you may need to use the calibration more than once to get it right on. I assume you resolved the other problems you had regarding your machine.
Eduardo
Active Member
Offline
Reply #7 on:
September 12, 2010, 09:17:21 AM »
Thank You very much for your answer,
Yes, I have been making improvements, now I am building a plasma machine which is 9ft x 6 ft (approx). I have followed your suggestion and my machine is by far working better.
What I am trying now is to implement the following features in this laser machine:
1) Stopping when the torch stops, so the G code would be easy to find to continue on.
If you have any suggestion how to implement this, I would appreciate it very much.
Thank You.
Eduardo
poppdsworkshop
Holding
Offline
Reply #8 on:
February 07, 2011, 11:36:12 AM »
something that I found when calbrating my machine, when you have a large change in steps you will need to go back and adjust your motor volocity, or you stepper will miss steps and only move a very short distance.
David
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
