February 13, 2012, 05:43:37 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  FAQs
| | |-+  Port 1 Pins not lighting
Pages: 1   Go Down
Print
Author Topic: Port 1 Pins not lighting  (Read 497 times)
fatogga
Active Member
Offline Offline
View Profile
« on: July 26, 2010, 03:22:00 PM »
Please help if you can.
Had to replace computer from a crash and ever since my port 1 pins ( on the diagnostics screen) aren't lighting although my CNC machine works great.
Any thoughts
Al
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #1 on: July 27, 2010, 03:28:01 AM »
You are not alone here Al - mine don't work either.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
fatogga
Active Member
Offline Offline
View Profile
« Reply #2 on: July 27, 2010, 09:59:53 AM »
Just spent the best part of a day going through your Website and was obviously quite impressed.
Where do you get the energy? Keep up the good work!
Al
fatogga
Active Member
Offline Offline
View Profile
« Reply #3 on: July 27, 2010, 10:01:39 AM »
Sorry, last reply was to Tweakie
Al
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #4 on: July 27, 2010, 11:07:52 AM »
Thanks Al.
I use the periods when the machine is running unattended to update the website and browse the forum.
Still hasn't got us any nearer to getting the led's to work. Mine used to work, long while ago, but haven't worked for 2 or 3 updates now. It is probably in the .xml somewhere but somebody must know the answer to this one.
In the meantime - I use Parmon which can be downloaded from here http://www.geekhideout.com/parmon.shtml
fatogga
Active Member
Offline Offline
View Profile
« Reply #5 on: July 27, 2010, 02:37:58 PM »
HI,
Well guess what. They now work and I don't know specifically why . . . Don't you hate that.
Anyway, I didn't have my limit switches reconnected from my last crash so thought I'd see if I could get their lights triggered when hit with no luck.
Then I tried the automated set up for limit switches and that didn't work either.
However, it was at this point that my Port 1 pins started working again. Hmmmm???
Anyway, success is success. I'll take it any way I can.
Thanks for feedback and the parmon download. Keep on Cuttin'
Al
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #6 on: July 28, 2010, 12:37:56 AM »
Glad you got it sorted Al.  Smiley
Pages: 1   Go Up
Print
Jump to:
