May 26, 2012, 02:06:21 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach SDK plugin questions and answers.
| | |-+  Add dll in VS2008 project plugin ?
Pages: 1   Go Down
Print
Author Topic: Add dll in VS2008 project plugin ?  (Read 1204 times)
cncstep
Active Member
Offline Offline
View Profile WWW
« on: July 22, 2010, 12:47:04 PM »
Prompt as it is possible in vs2008 to connect dll library and how to call from it functions?
freedom2000
Active Member
Offline Offline
View Profile
« Reply #1 on: July 23, 2010, 12:57:36 PM »
Hi have exactly the same question (with an HIDclass dll) an no answer ...
so following also your thread !
JP
cncstep
Active Member
Offline Offline
View Profile WWW
« Reply #2 on: July 25, 2010, 11:34:40 PM »
Let's wait
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #3 on: August 11, 2010, 09:56:05 AM »
what are you trying to do?  Are you trying to call a DLL from inside of a Mach plugin? or what?
scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
freedom2000
Active Member
Offline Offline
View Profile
« Reply #4 on: August 11, 2010, 10:18:17 AM »
scott
I am not the author of this thread, but as I had the same question... Yes I wanted to call a dll from a Mach3 plugin.
I have now succeeded.. My only problem was that the dll must be located in the same folder as Mach3.exe and not into the plugin directory...
It was finally simple :-)
JP
cncstep
Active Member
Offline Offline
View Profile WWW
« Reply #5 on: May 15, 2011, 12:50:51 AM »
scott
I try to cause the dll to work with 3d laser scanner. To make the plugin to scan the surface to a file with a cloud of points.
Pages: 1   Go Up
Print
Jump to:
