Hello Guest it is June 09, 2026, 06:33:50 PM
Author Topic: Add dll in VS2008 project plugin ?  (Read 12936 times)
« on: July 22, 2010, 12:47:04 PM »
Prompt as it is possible in vs2008 to connect dll library and how to call from it functions?
Re: Add dll in VS2008 project plugin ?
« Reply #1 on: July 23, 2010, 12:57:36 PM »
Hi have exactly the same question (with an HIDclass dll) an no answer ...
so following also your thread !
JP
« Reply #2 on: July 25, 2010, 11:34:40 PM »
Let's wait
« Reply #3 on: August 11, 2010, 09:56:05 AM »
what are you trying to do?  Are you trying to call a DLL from inside of a Mach plugin? or what?
scott
« Reply #4 on: August 11, 2010, 10:18:17 AM »
scott
I am not the author of this thread, but as I had the same question... Yes I wanted to call a dll from a Mach3 plugin.
I have now succeeded.. My only problem was that the dll must be located in the same folder as Mach3.exe and not into the plugin directory...
It was finally simple :-)
JP
« Reply #5 on: May 15, 2011, 12:50:51 AM »
scott
I try to cause the dll to work with 3d laser scanner. To make the plugin to scan the surface to a file with a cloud of points.
