Hello Guest it is June 11, 2026, 01:52:21 PM
Author Topic: Stop button press loses comm with SS  (Read 12372 times)
« on: July 20, 2010, 04:55:57 PM »
I am using the current dev version with the new standard screenset and when ever I press the stop button after appx 1 sec it get the error screen that the SS has run out of data.  Anyone know how to fix this?
Tom
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Stop button press loses comm with SS
« Reply #1 on: July 20, 2010, 08:57:51 PM »
I would not use the developent version with the SS. Use the latest lockdown version of Mach with the lates SS plug-in and driver.
Happy machining , Jeff Birt
« Reply #2 on: July 21, 2010, 07:20:59 AM »
Thanks Jeff, I normally use the lockdown version , I was just trying out the new screenset and it requires the current Dev version.
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: July 21, 2010, 08:17:22 AM »
The development verions are typically made to test a new feature and are not tested for compatibility with all the other things out there for Mach. The downside is that it might or might not work.
