Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 01:27:48 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
General Mach Discussion
Help Please! arcs in Mach turn
Pages:
1
Go Down
« previous
next »
Author
Topic: Help Please! arcs in Mach turn (Read 384 times)
theshed
Active Member
Offline
on:
July 19, 2010, 04:14:41 PM »
Hi
I have retrofitted my lathe and all is fine. Simple x and z cuts seem very accurate. But...I have hand written code to produce a pawn shape (No that was spelt correctly!) I am using a series of subroutines with G2 and G3 cuts using the I K system. My all dimensions are in mm to 4 decimal places. After 30 loops the position has drifted significantly by around 0.5mm per axis. What am I doing wrong??
I am on Servo motors with 2000 resolution encoders.
I have adjusted Gibs, backlash in the belts, the ballscrews seem fine.
I have slowed down velocity and acceleration to a fraction of what the servos can cope with.
I have broken each arc down into a separate subroutine in order that the errors do not add up - minor improvement
I have broken arcs that intersect axis lines (causing the motors to reverse) into separate sections.
I could get around the error multiplication by resetting zeros before a final cut but that seems very crude.
Are arc moves generally inaccurate or is it me?
Active Member
Offline
Carnoustie, Scotland
Re: Help Please! arcs in Mach turn
Reply #1 on:
July 19, 2010, 04:34:11 PM »
Arcs are fine for me on my lathe. Can you monitor the encoders in your drives software?
Global Moderator
Offline
Reply #2 on:
July 19, 2010, 04:45:18 PM »
I never found any problem with ARC's on my lathe.
Any cutting on the lathe will only be as accurate as your machines system.
Hood can help more relative to setup since you use servos.
theshed
Active Member
Offline
Reply #3 on:
July 20, 2010, 02:17:25 AM »
Everything I know about electronics has been learned on this project so I am a little bit slow! I am using a dual servo drive from Granite Devices. There is software to monitor the encoder although I think that requires me to disconnect the BOB. If I can manage that what should I be looking for?
Many thanks for your prompt responses. This is my first experience with Mach3 - previous and very dead control was 1980s Anilam - its quite a jump up.
John
Active Member
Offline
Reply #4 on:
July 20, 2010, 03:44:12 AM »
What I am thinking is it may be a tuning issue.
If you can monitor the encoder position whilst Mach is running then you could run some code and have some M1's in the code and take a note of the encoder reading at each M1, Run the code over and over and see if the encoder readings are the same on each run.
theshed
Active Member
Offline
Reply #5 on:
July 20, 2010, 04:53:58 AM »
I think you are right. I tuned the motors carefully but only thereafter noticed that the gibs were loose in Z and belts loose in X and Z. I will retune and see what happens. Many thanks for your help. I can see that you are a great supporter of the forum - many thanks.
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
