May 26, 2012, 12:54:16 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  "No Driver Sensed"
Pages: « 1 2   Go Down
Print
Author Topic: "No Driver Sensed"  (Read 624 times)
patrick
Active Member
Offline Offline
View Profile
« Reply #10 on: July 18, 2010, 05:47:42 PM »
Older versions are giving me the same notice.  I uninstalled everything and reinstalled. I just keep getting the same notice. It had been working fine for over a year. I had updated before without issue. This time however something seems to have changed that is preventing that driver from being installed.
 patrick
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #11 on: July 18, 2010, 06:03:40 PM »
Cant recall anyone having that issue so really I am out of ideas, only other thing I can think of is disable any anti virus while installing Mach, but to be honest I dont see that would be the problem.
Maybe someone else will have an idea.
patrick
Active Member
Offline Offline
View Profile
« Reply #12 on: July 18, 2010, 07:00:45 PM »
A few clumps of hair later I found that the device driver for the parallel card I have was not functioning. I don't see how the mach Update would cause that, but the events happened at the same time.  Reinstalling the card driver allowed the The pulse test now operates successfully.
 I deleted my licence though and I can't find the email it came in. Is there a way to retrieve it from art soft?
 patrick
 disregard I found the licence in the trash.
 Now I have to go though and tune everything again. It is update to the current lock down though Smiley
 patrick
« Last Edit: July 18, 2010, 07:08:34 PM by patrick » Logged
Active Member
Offline Offline
View Profile
« Reply #13 on: July 19, 2010, 01:19:42 AM »
Patrick
 Good to hear you found the problem. For future reference once you get things set up save the xml and licence file on another drive or a memory stick, CD or whatever, that way if your drive dies or any other problems you can get back up and running with all your old settings in a few mins.
Pages: « 1 2   Go Up
Print
Jump to:
