May 26, 2012, 12:08:01 PM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Works in progress
| | | |-+  Mach Blue Probing
Pages: 1   Go Down
Print
Author Topic: Mach Blue Probing  (Read 5884 times)
big-tex
Active Member
Offline Offline
View Profile
« on: July 12, 2010, 10:58:24 PM »
Ok here is Mach Blue moded screen with touch off and laser XY zero.
It has been designed to be used with router as coolant botton has been moded.
Touch off options will detect if native unit are English or metric.
Feel free to test and post opinions.
download link http://www.cnczone.com/forums/showthread.php?t=100594
Thomas
big-tex
Active Member
Offline Offline
View Profile
« Reply #1 on: November 29, 2010, 03:26:12 PM »
I would like to further develop this routine and have question maybe someone can help me.
I would like to add to script command to start cycle  as I understand DoOemBotton (1000) should work.
But it does not, is this known bug or Mach was designed that way so you can not call this command in scripts?
Is there workaround?
Thomas
big-tex
Active Member
Offline Offline
View Profile
« Reply #2 on: November 29, 2010, 10:23:26 PM »
i got it figured out
Code DoButton(0)            'Cycle Start
Thomas
electric2u
Active Member
Offline Offline
View Profile
« Reply #3 on: January 14, 2011, 05:24:57 PM »
my home switch and probing switch are not working can i have some help,  ( yes i did check the ports and pin and they are there, realy would like this to work)
Kevin
Libbit
Active Member
Offline Offline
View Profile
« Reply #4 on: March 19, 2012, 03:22:46 PM »
Hi, I've just loaded and setup this screen and would like to know which M?Huh??.m1s macro runs the z height touch probe?
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #5 on: March 19, 2012, 05:02:38 PM »
I believe the macro's are saved with the buttons, and don't use M codes.
Libbit
Active Member
Offline Offline
View Profile
« Reply #6 on: March 19, 2012, 06:13:25 PM »
Hi, thank you will try out tonight when i get home.
santiniuk
Global Moderator
Offline Offline
View Profile
« Reply #7 on: May 05, 2012, 03:59:41 PM »
It's been some time since I visited the forum but would like to ask that the text request for Paypal donations for this screen set is removed from the downloads section.
The screen sets that Mr Bean and Myself developed are free to this great community and It's disappointing to see that our work has been copied and then the 'author' offering an address for Paypal donations.
SantiniUK
Global Moderator
Offline Offline
View Profile
« Reply #8 on: May 07, 2012, 05:04:05 PM »
Hello there SantiniUK. Never met ya but obviously you were before my time..... Cheesy
When I tried downloading the screen set I didn't get a PayPal prompt. Huh
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #9 on: May 07, 2012, 05:07:42 PM »
He's talking about the text at the bottom of the description here http://www.machsupport.com/screens.php
You need to send an email to Scott to get that changed.
Pages: 1   Go Up
Print
Jump to:
