Hello Guest it is June 11, 2026, 01:15:26 PM
Author Topic: Motor Controller front panel control suggestions?  (Read 22261 times)
Re: Motor Controller front panel control suggestions?
« Reply #10 on: July 25, 2010, 08:38:49 AM »
Ok so feedhold is essentially Pause then. got it.
What does go to Z10 do?
Offline khalid
  •  213 213
    • My Wood carving
« Reply #11 on: July 25, 2010, 11:03:02 AM »
Hood.. Wow wow and Wow.. Excellent control panel.. I am also planning to make one for my Mill... I just want to know what screen set you are using?... Its very beautiful and sober..
« Reply #12 on: July 25, 2010, 11:34:25 AM »
Some buttons and stuff i plan on putting on a pendant with basic controls on the motor controller box. which will be in a cabinet out of the way with the PC and just have basic controls for testing and what not with the pendant doing most of the full time work. so I will add a full array of controls for the pendant box.
 But On/Off
XYZ axis controls
Spindle on/off
Vacuum On/Off
Coolant On/Off
Start
Stop
Pause
Home
stuff like that I will add to the motor box
« Reply #13 on: July 25, 2010, 01:29:20 PM »
That is just a button I find handy, I have it so that when I press it the Z rises to 10mm in work coords.
The screen on the lathe (lower pic) is just an adaption of the first mill screen I made , the one in the top pic is my next incarnation of a screen and has LEDs built into a lot of the buttons. The screensets are very personal to the machines so wouldnt be much use to others, especially the new mill one as it has a  lot of VB buttons.
I made the new screen to be mainly a one page screen so that the controls I use 99% of the time are on the one page. I have a page for my toolsetter, an unfinished Diagnostics page and a large toolpath page.
You can see a better pic of it here. http://www.machsupport.com/forum/index.php/topic,10331.50.html
I am quite happy to pass on the buttons folder so you can make your own up if you wish.
 But On/Off
XYZ axis controls
Spindle on/off
Vacuum On/Off
Coolant On/Off
Start
Stop
Pause
Home
Sounds like a nice list :)
« Reply #14 on: January 27, 2011, 05:40:09 PM »
So is there any other button that is Mach3 related that really should be on the front panel??
« Reply #15 on: January 27, 2011, 05:49:36 PM »
I like my optional stop button, then of course the FRO and SRO pots but you need analogue for that.
« Reply #16 on: January 27, 2011, 05:54:15 PM »
I have a stop button planned. But im looking for anything that is imperative to have for basic Mach3 operation. anything you need quick access to. I am not familiar enough with the software or CNC machining to know.
« Reply #17 on: January 27, 2011, 06:04:02 PM »
I was meaning optional stop rather than stop.
Its a hard one to call, just depends on how you use the machine, might be best to make up a panel so you can add if needed once you start using it and find you would really like a button for some function.
