Hello Guest it is June 12, 2026, 05:27:50 AM
Author Topic: Macro deactivate thc up and thc down  (Read 11818 times)
« on: July 05, 2010, 05:10:17 PM »
I apologize but I do not write very good English, I am using plasma MACH3
and thc 300, I have a problem in circles, when thc does not disable the delay in drilling, is that there is a macro to turn off the thc, but this way there is no delay in the cut, anyone can write a macro to clear the thc-up entries
and thc down?, (and another to activate, of course.
Thanks for the help.
Re: Macro deactivate thc up and thc down
« Reply #1 on: July 05, 2010, 06:01:12 PM »
Sorry I don't quite get what you mean by
" when thc does not disable the delay in drilling" All the THC does is move the z up or down based on tip voltage compared to set voltage
« Reply #2 on: July 05, 2010, 06:16:28 PM »
When cutting circles turn off the thc, but thc off with no signal detected arc ok,
and I can not implement pierce delay.
The entries disable thc thc up and down, so does the arc ok.
« Reply #3 on: July 05, 2010, 07:05:54 PM »
it would also be a script that will disable thc down under acceleration, deceleration and circles, the feedrate is always lower in Cirules that f g code, something like
 if feedrate  < f (gcode) -100 Then disable thc down
« Reply #4 on: July 05, 2010, 07:36:51 PM »
That type of operation would have to be done through a plugin to mach.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #5 on: July 06, 2010, 04:01:39 AM »
sounds like you need to use anti-dive.
