May 26, 2012, 10:03:25 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Question about excel files of OEM CODES
Pages: 1   Go Down
Print
Author Topic: Question about excel files of OEM CODES  (Read 428 times)
renenpaz
Active Member
Offline Offline
View Profile
« on: July 02, 2010, 09:55:11 AM »
Recently I downloaded two excel files containing OEM codes and other codes.
I don't what use for DoOemButton (    )
I attach both here.
Also in Wiki are another tables..
What should I use?
Please explain me the use of each one,
Thanks in advance
Rene
* OEM CODE FILES.rar (74.61 KB - downloaded 77 times.)
renenpaz
Active Member
Offline Offline
View Profile
« Reply #1 on: July 02, 2010, 05:07:02 PM »
Sorry, Forget to say that Iam using Mach 3 v042.020
No plans for Mach3 V4.
What tables should I use for OEM codes?
Rene
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #2 on: July 02, 2010, 05:33:55 PM »
For the OEM codes you will need to use the old ones for Rev3
renenpaz
Active Member
Offline Offline
View Profile
« Reply #3 on: July 03, 2010, 12:00:04 PM »
Thanks Hood.
sl2
Rene
Pages: 1   Go Up
Print
Jump to:
