Hello
Guest
it is
June 08, 2026, 11:29:42 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Is anyone else using E1P1 / E1P0 to switch output #1 ?
« previous
next »
Print
Pages:
1
2
3
4
Go Down
Author
Topic: Is anyone else using E1P1 / E1P0 to switch output #1 ? (Read 44385 times)
BR549
6,965
Re: Is anyone else using E1P1 / E1P0 to switch output #1 ?
Reply #30 on:
July 05, 2010, 11:48:56 AM »
HUM that is interesting. Art stated early on that the E1p0/1 was to be ONLY Used on a line by itself. If used on mixed line it would error out as bad code syntax error.
BR549
6,965
Reply #31 on:
July 08, 2010, 07:35:15 PM »
TWEEKIE, Question on the E1p0(;-) How are you generating your Gcode for laser???
Tweakie.CNC
9,356
Super Kitty
Reply #32 on:
July 09, 2010, 12:30:18 AM »
The example I have been using was created using a Roland engraving program which outputs HPGL, this was then converted to GCode. Then I edit the Z moves to the E1P0....
BR549
6,965
Reply #33 on:
July 09, 2010, 04:38:40 PM »
OK Thanks, I found a slight M5 delay in sheetcam gcode output and was wondering if you were useing that.
Print
Pages:
1
2
3
4
Go Up
« previous
next »
