Hello
Guest
it is
June 09, 2026, 04:38:27 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
help with DC DC converter
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: help with DC DC converter (Read 12805 times)
maestro123
9
on:
June 25, 2010, 10:24:11 AM »
hi,
I am fortunate to have a dc dc converter
to minimize the noise in the system
but I did not find how to connect
here is the datasheet of the main element "AFC5"
is that someone can help me to connect
thank you in advance
Tweakie.CNC
9,356
Super Kitty
Re: help with DC DC converter
Reply #1 on:
June 25, 2010, 10:39:53 AM »
What do you hope to achieve by using the device please ?.
It appears to be a serial / parallel or parallel / serial converter of some sort but I am uncertain of it's application.
maestro123
9
Reply #2 on:
June 25, 2010, 04:32:34 PM »
hi tweakie,
it's destinate to decrease noise and i have taked it from a professional cnc machine
Tweakie.CNC
9,356
Super Kitty
Reply #3 on:
June 26, 2010, 12:09:20 AM »
Thanks for the explanation, I understand now.
Do you have noise on the drive signals, limit switch inputs or the power lines ?.
maestro123
9
Reply #4 on:
June 26, 2010, 04:08:57 AM »
No Tweakie for the moment i have not noise.
One time it happened that X axis made unexpected movement..!!
The manufacturer said that this system is designed to keep very low noise, so i think that is professional to have "AFC5".
Tweakie.CNC
9,356
Super Kitty
Reply #5 on:
June 26, 2010, 11:03:59 AM »
Hi again,
I have searched the internet for more info on this assembled AFC5 device of yours without success.
My suggestion is that you forget about it - a dc to dc converter in itself would do little if anything to reduce any electrical noise in a CNC system anyway. If you feel that you have a noise problem then some very good tips have been detailed by Bob Warfield both here
http://www.cnccookbook.com/CCCNCNoise.html
as well as on this forum.
Sorry I can't be of more help.
Best regards,
maestro123
9
Reply #6 on:
June 28, 2010, 05:43:07 PM »
Thanks Tweakie...
Print
Pages:
1
Go Up
« previous
next »
