Hello Guest it is June 09, 2026, 03:39:57 AM
Author Topic: Bass Boat Dash Plates  (Read 28265 times)
Re: Bass Boat Dash Plates
« Reply #10 on: June 30, 2010, 08:15:44 PM »
Nice work
And can I ask where you got the material and what it is?
Offline Garyv
  •  103 103
« Reply #11 on: July 01, 2010, 07:42:35 AM »
I get the material from a local plastic supplier, I forgot what the brand or type material it is , but it is used a lot for dash plates on boats . It is not starboard its harder than starboard and a little softer than acylic. From what I understand it is a crosss between the 2. the material that I usually get are drops from the local suppier so it did not have the label on it.It is nice material to cut. I used to use starboard for a lot of bigger dashes until I found this from the supplier..Next trip to the supplier I am going to get the braand name , I have had a few people ask what it is.
 I usually cut it at 60 IPM at 10000 RPM..
« Reply #12 on: July 01, 2010, 12:34:57 PM »
thanks for the info.  my boat is getting up there,
« Reply #13 on: July 01, 2010, 12:44:15 PM »
For it worth, moulded dash boards are usually ABS resin. Might well be that your plates are also ABS. It also machines well.
Daniel
Offline Garyv
  •  103 103
« Reply #14 on: November 13, 2010, 02:25:53 PM »
It is ABS and come in a few colors and machines great , Here is a few pictures of some other dashes that I did for a 65 footer..
Had to do a little creative ingeneering to get LED lighting in it though..The top hole is for radar unit and the lower hole is for a VHF radio..
ALso I have a few pics of a name plate for my Neice to put on her Desk..
Hope you like these.
Gary
« Last Edit: November 13, 2010, 02:27:25 PM by Garyv »
