May 26, 2012, 08:23:03 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  2nd parallel port
Pages: 1   Go Down
Print
Author Topic: 2nd parallel port  (Read 435 times)
jekran
Active Member
Offline Offline
View Profile
« on: June 23, 2010, 07:47:13 AM »
hi guys
i just brouth a pci parallel port  and i instail it but when i whent to find the adress in the device manager there is no resources tap so i cannot see the adress
is there an other way where you can see the adress ?
the driver of this card is sun-4008t
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: June 26, 2010, 04:36:55 PM »
Windows Start button > All Programmes > Accessories .> System Tools > System Information > Components > Ports > Parallel and then you should see the address.
Pages: 1   Go Up
Print
Jump to:
