May 26, 2012, 08:22:26 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Mach3 & Calculator
Pages: 1   Go Down
Print
Author Topic: Mach3 & Calculator  (Read 466 times)
mrpeja
Active Member
Offline Offline
View Profile WWW
« on: June 23, 2010, 02:06:33 AM »
I'm playing with Mach R3.042.040 Demo version.
Any attempt to change DROs in Run Screen opens an calculator.
IS THIS NORMAL, OR WHAT HAPPENS?
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline Offline
View Profile
« Reply #1 on: June 23, 2010, 04:02:02 AM »
Forgive me as I do not have Mach 3 in front of me at the moment but that option is switched on somehow.
It's in one of the upper windows menus along the top and it's called Auto Calculator (or something like that). Just click it (uncheck) and the DROs should work correctly.
Dave->    Wink
Tweakie.CNC
Active Member
Offline Offline
Super Kitty.
View Profile WWW
« Reply #2 on: June 23, 2010, 04:12:58 AM »
Dave has an excellent memory - Auto Calculator is under the 'Operator' menu tab.
Success consists of going from failure to failure without loss of enthusiasm.  Winston Churchill.
Pages: 1   Go Up
Print
Jump to:
