May 26, 2012, 08:21:46 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Y, U, V Change X DRO
Pages: « 1 2   Go Down
Print
Author Topic: Y, U, V Change X DRO  (Read 989 times)
BR549
Active Member
Offline Offline
View Profile
« Reply #10 on: June 26, 2010, 08:49:05 AM »
OK I will ask the obvious, You said that the mache has 1 axis "X" AND that the Cam puts out multi levels of code as Y,U,V.
Is the machine in it's original configuration with only 1 axis?
It does not make sense for the CAM to output YUV if the machine only has X?Huh??
What do the YUV commands do on the machine?
ger21
Global Moderator
Online Online
View Profile WWW
« Reply #11 on: June 26, 2010, 09:12:21 AM »
The machine is a beam saw. Sheet goods are clamped and moved along the table, and stopped for the saw to make cuts. The X axis is probably the sheet movement. The saw carriage should not be any axis.
My guess is that the code outputs other axis for crosscuts. On a typical beam saw, the saw first rips the sheet into multiple strips, Then, each strip is placed back into the saw to make the crosscuts. So, both X and Y cuts on the material are done with one axis on the machine.
The biggest hurdles here is trying to make Mach3 do what it's not designed to do.
A better option imo is to modify the software output to something that works with Mach3, rather than trying to modify Mach3 to work with other software.
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #12 on: June 26, 2010, 12:48:08 PM »
Not sure what an optimizer is in this context but wouldn't it be better to configure your optimizer for your machine? Seems a bit AB to me  Smiley
Ian
KTM
Active Member
Offline Offline
View Profile
« Reply #13 on: June 27, 2010, 03:44:00 AM »
The other option is to open the g-code as a text document and use the edit - replace utility and replace the Y, U , and V
with a X
Csabika
Active Member
Offline Offline
View Profile
« Reply #14 on: June 29, 2010, 03:25:25 PM »
Hi!
KTM
I do not see where you are only the cut
Csaba
KTM
Active Member
Offline Offline
View Profile
« Reply #15 on: June 30, 2010, 01:33:17 AM »
Attach a G-Code file that you use on the machine and I will show you how to edit it.
Csabika
Active Member
Offline Offline
View Profile
« Reply #16 on: July 03, 2010, 03:51:14 AM »
Hi KTM!
Attach a G-Code file The X-Y-U-V
probe code
g0 x600
m7m1
x1200
m7m1
x1800
m7m1
y300
m7m1
u600
m7m1
v300
m7m1
m2m30
Hi Csaba
KTM
Active Member
Offline Offline
View Profile
« Reply #17 on: July 03, 2010, 07:00:20 AM »
Use the replace utility in notepad as shown
Regards
Steve
Pages: « 1 2   Go Up
Print
Jump to:
