Hello
Guest
it is
June 12, 2026, 06:59:14 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
VB and the development of wizards
Y, U, V Change X DRO
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Y, U, V Change X DRO (Read 20041 times)
Csabika
18
on:
June 22, 2010, 03:45:26 PM »
Hi!
how macro to be any axis in g code the x-axis move?
If G code Y300 you move X-axis 300
U300 you move X-axis 300
thanks
Csaba
Tweakie.CNC
9,356
Super Kitty
Re: Y, U, V Change X DRO
Reply #1 on:
June 23, 2010, 04:21:34 AM »
Hi Csaba,
Not quite sure what you are saying here.
Y300 will move the Y axis and DRO
U300 will move the A axis and DRO
Could you perhaps explain in more detail please ?
Csabika
18
Reply #2 on:
June 23, 2010, 01:46:49 PM »
Hi Tweakie!
Not.
Any axis is G code, always move the X axis and XDRO
the code line by line with the movements.
G code: G0 X500 ' move x axis 500mm
X800 ' move x axis 800mm
M01
G0 Y600 ' move x axis 600mm
M01
G0 U1100 ' move x axis 1100mm
M01
This is because it should be a panel sizing machines, and there is only one axis
but the cam software works at four levels, when the signal changes (x-y x-u x-v)
is waiting for an external signal.
Regards Csaba
Tweakie.CNC
9,356
Super Kitty
Reply #3 on:
June 24, 2010, 12:55:44 AM »
Hi Csaba,
Perhaps someone else can figure this one out but I really can't understand exactly what you are doing or just why you would use multi-axis software / GCode just to control one machine axis.
I know it's not resolving your problem but I would like to understand (assuming it's not totally beyond me) exactly what you are doing with this machine.
KTM
92
Reply #4 on:
June 24, 2010, 01:56:19 AM »
In ports and pins, set your x axis, y axis and a axis output the same and set the tuning as the same, as long as you do not move the axes at the same time, it should work.
eg: step pin # 7
dir pin # 6
Regards
Steve
Csabika
18
Reply #5 on:
June 25, 2010, 08:42:53 AM »
Hi Steve!
problem with me using it, motion control DSPMC and can not be given the same number of output shaft.
Regards Csaba
Csabika
18
Reply #6 on:
June 25, 2010, 08:44:13 AM »
Someone help please very important.
Csaba
KTM
92
Reply #7 on:
June 25, 2010, 08:51:34 AM »
Is there any specific reason why you are using the DSPMC instead of the parallel port break out board?
stirling
2,188
UK
Reply #8 on:
June 25, 2010, 10:09:13 AM »
Csaba
I'm with Tweakie on this. Why are you generating code that is unsuitable for your machine? This just doesn't seem the right way to go about things and it sounds potentially dangerous too.
sometimes it's better to ask for solutions to the actual problem rather than asking how to implement your solution to a problem you havn't told us about.
Ian
Razordance Torch Height Control
Csabika
18
Reply #9 on:
June 26, 2010, 08:18:39 AM »
Hi Ian!
I used to be so because the optimizer does the code.
KTM!
The dspmc be because the enginedriver analog + / - 10V
Csaba
Print
Pages:
1
2
Go Up
« previous
next »
