Hello Guest it is June 09, 2026, 06:42:43 PM
Author Topic: How to run a script after each Gcode in single step mode  (Read 20430 times)
Re: How to run a script after each Gcode in single step mode
« Reply #10 on: June 28, 2010, 08:53:26 AM »
I retrofit a punch press last year http://www.machsupport.com/forum/index.php/topic,11844.msg75764.html#msg75764. I programmed a macro for punching (M20) and put it manually to the end of each line of G0 commands created with drill cycles. I use Excel spreadsheet to edit and put M20 after each line. Just a matter of cut and paste. Takes less than a minute.
Zafar
« Reply #11 on: June 30, 2010, 10:38:22 AM »
Hi Zafar,
Thanks for your tip!
I like the screen, is it your design?  Could I use it for a fee?
I was thinking to use the plasma screen.
Luis
« Reply #12 on: July 01, 2010, 01:40:11 AM »
Luis,
Yes I designed the screens. Here's a snapshot of the screens. Do you need just the screens or the macros too. PM me or contact me direct at zafar@zafar.com.pk
Zafar
