Hello
Guest
it is
June 10, 2026, 06:54:51 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Paralell port trouble
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Paralell port trouble (Read 21594 times)
mrpeja
114
on:
June 18, 2010, 11:42:27 AM »
I just installed brand new 2,2 GHz main board and Mach in demo mode. I tested printing on Laser printer. Is OK.
But I have no communication with machine, no Charge pump signal, all inputs are inactive.
Any idea?
mrpeja
114
Re: Paralell port trouble
Reply #1 on:
June 18, 2010, 11:55:51 AM »
Let me post more data:
I measured with scope direct on port. Port address is ok in Mach and the same as in Windows.
Maybe demo mode has no output to port?
Carnoustie, Scotland
Reply #2 on:
June 18, 2010, 12:09:28 PM »
What do you mean by Demo mode?
If you are meaning you chose not to load the driver then it wont output, if you are just meaning you have no licence then it should work fine.
mrpeja
114
Reply #3 on:
June 18, 2010, 12:11:15 PM »
I mean, i loaded driver, I don't have license yet
Reply #4 on:
June 18, 2010, 12:14:33 PM »
Then it should work fine if you have it configured correctly.
mrpeja
114
Reply #5 on:
June 18, 2010, 12:15:59 PM »
It looks I must examine parallel port extension cable I buyed.
Thanks Hood
Reply #6 on:
June 18, 2010, 12:17:49 PM »
I would say check directly on the port with your meter or scope and that will let you know if the problem is in the computer or outside.
mrpeja
114
Reply #7 on:
June 18, 2010, 12:20:36 PM »
That's interresting ! This port is working for printer and not for Mach !
Reply #8 on:
June 18, 2010, 12:23:27 PM »
Is it an onboard port?
mrpeja
114
Reply #9 on:
June 18, 2010, 12:31:53 PM »
Yes, it is onboard port
Print
Pages:
1
2
Go Up
« previous
next »
