Hello Guest it is June 10, 2026, 06:56:38 PM
Author Topic: Paralell port trouble  (Read 21602 times)
Offline mrpeja
  •  114 114
    • Embroidery Machines
« on: June 18, 2010, 11:42:27 AM »
I just installed brand new 2,2 GHz main board and Mach in demo mode. I tested printing on Laser printer. Is OK.
But I have no communication with machine, no Charge pump signal, all inputs are inactive.
 Any idea?
Offline mrpeja
  •  114 114
Re: Paralell port trouble
« Reply #1 on: June 18, 2010, 11:55:51 AM »
Let me post more data:
I measured with scope direct on port. Port address is ok in Mach and the same as in Windows.
Maybe demo mode has no output to port?
« Reply #2 on: June 18, 2010, 12:09:28 PM »
What do you mean by Demo mode?
If you are meaning you chose not to load the driver then it wont output, if you are just meaning you have no licence then it should work fine.
Offline mrpeja
  •  114 114
« Reply #3 on: June 18, 2010, 12:11:15 PM »
I mean, i loaded driver, I don't have license yet
« Reply #4 on: June 18, 2010, 12:14:33 PM »
Then it should work fine if you have it configured correctly.
Offline mrpeja
  •  114 114
« Reply #5 on: June 18, 2010, 12:15:59 PM »
It looks I must examine parallel port extension cable I buyed.
Thanks Hood
« Reply #6 on: June 18, 2010, 12:17:49 PM »
I would say check directly on the port with your meter or scope and that will let you know if the problem is in the computer or outside.
Offline mrpeja
  •  114 114
« Reply #7 on: June 18, 2010, 12:20:36 PM »
That's interresting ! This port is working for printer and not for Mach !
« Reply #8 on: June 18, 2010, 12:23:27 PM »
Is it an onboard port?
Offline mrpeja
  •  114 114
« Reply #9 on: June 18, 2010, 12:31:53 PM »
Yes, it is onboard port
