VIA 1GHz CPU WITH 1GB DDR2 RAM, 80GB IDE Harddrive.
Manufacturers website:
http://www.via.com.tw/en/products/embedded/artigo/a1000/index.jspLow power and Ultra small, portable pc. Smaller than a DVD drive. Please see attached images, the first three are stock photos but the last one is of the actual computer. I have ran these with Smoothsteppers and they work great.
Case has some scratches and some epoxy on bottom where clips were glued on. Still not a bad looking case and is in perfect working condition. Xubuntu is currently installed but can run windows xp just fine (that is what was originally on it and the genuine sticker for windows xp with sp3 is still on the case.)
Complete Specs:CPU: VIA C7 1GHz Processor
Memory: 1GB DDR2 667 SODIMM Socket
Hard Disk: 80GB IDE 2.5" Hard Disk
(Also supports one SATA drive)
USB Ports: 4 USB 2.0 ports
LAN Port: 1 10/100Mbps RJ-45 LAN port
Audio: Build-in High Definition Audio
Audio Ports: 1 Microphone-in jack, 1 Line-out jack
Display Port: 1 VGA port (Also has DVI suport)
Dimensions: 5.9"(L) x 4.3"(D) x 1.8"(H) (15cm x 11cm x 4.5cm)
Average System Weight: 1.14 lbs (520g)
$125.00 USD plus shipping
