May 26, 2012, 06:57:57 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  cut circle wizard will not post
Pages: 1   Go Down
Print
Author Topic: cut circle wizard will not post  (Read 453 times)
Viktor
Active Member
Offline Offline
View Profile
« on: June 14, 2010, 03:33:44 PM »
This is the message I read : MSG.ToolDia(arrow)Dia
Meaning I guess dia data missing? I entered 0.25
If I enter 0 it tells me it can't be 0. So?
In config, I have tool no 1 with .25 dia., cv abs (tried both Sad)
other wizards (the ones I tried)  are working properly.
Don't know where to look at. Smiley
Any help appreciated.
Pierre
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: June 14, 2010, 04:56:34 PM »
Can you post a screenshot of the values you have entered and I will put the same in here and see what happens, that way I can maybe figure out your problem.
Viktor
Active Member
Offline Offline
View Profile
« Reply #2 on: June 14, 2010, 06:39:33 PM »
Can't screenshot:working on 2 separate computers.
But here are the readings:
Tool Dia:+0.25
Safe Z :+2.000
Job Z :0.0000
Circle Dia: +1.5000
Depth: 0.7500
x center:+4.25
ycenter:+3.75
clerance: 1
plunge feed:20
rough feed: 30
step depth:0.1000
finish feed: 20
final cut depth: 0.75
motion and dist modes are cv, IJ modes is abs
Active Member
Offline Offline
View Profile
« Reply #3 on: June 14, 2010, 07:03:57 PM »
Ok what it is telling you is the cutter Dia is larger than the circle Dia. That  is because you have a cutter Dia of 0.25 and a final cut depth of 0.75. The Final Cut depth is actually meaning a final pass width and not depth I think. Put 0 in there and it should work fine.
Viktor
Active Member
Offline Offline
View Profile
« Reply #4 on: June 14, 2010, 07:48:02 PM »
Indeed it works!
Hum.....need to improve my reading.........
Thank you Hood.
Pierre
Active Member
Offline Offline
View Profile
« Reply #5 on: June 15, 2010, 01:16:09 AM »
It is worded badly when it says Final Cut Depth, would have been better if it said Finish Cut  Amount or something like that.
Pages: 1   Go Up
Print
Jump to:
