May 26, 2012, 06:57:20 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  Zero X +Y button?
Pages: 1   Go Down
Print
Author Topic: Zero X +Y button?  (Read 533 times)
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline Offline
View Profile
« on: June 14, 2010, 02:30:37 PM »
Hi all,
Yes, it's another dumb simple VB question from me.
I would like a button on my screen to Zero the X + Y DRO's together with one press.
I know I can use the OEM codes 1008 (X) and 1009 (Y), but how do I make a VB script to do this?
Thank you kindly-
Dave->    Wink
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #1 on: June 14, 2010, 03:37:36 PM »
You could use this code as your button script
SetOEMDRO (800,0)
SetOEMDRO (801,0)
Greg
budman68
Global Moderator
Offline Offline
View Profile
« Reply #2 on: June 14, 2010, 03:44:32 PM »
Worked perfectly Greg, thank you very much.
Now I realized you're using the OEM codes for the DROs, but how did you know how to put the comma and add the zero's to actually zero the DRO? Is it just from fooling around with VB, or do you actually know VB scripting/code?
Again, thank you- Smiley
Dave->    Wink
Greolt
Global Moderator
Offline Offline
View Profile
« Reply #3 on: June 14, 2010, 03:47:19 PM »
The little I know of this stuff is just by looking at other examples and fooling around with it.  Smiley
Greg
budman68
Global Moderator
Offline Offline
View Profile
« Reply #4 on: June 14, 2010, 03:48:49 PM »
Ah, I guess that's how I'll be "learning" as well, lol!
Dave->    Wink
stirling
Global Moderator
Offline Offline
UK
View Profile WWW
« Reply #5 on: June 15, 2010, 07:29:18 AM »
There's useful info for things like this in the WIKI including a Cypress VB manual such as it is.. There is I believe a newer version of the (Mach specific) VB reference written by (I think) HimyKabibble but I'm not sure where it is. Maybe a sticky at the top of this topic would be an idea?
Ian
Pages: 1   Go Up
Print
Jump to:
