May 26, 2012, 05:50:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Driver test and motor tuning not working
Pages: 1   Go Down
Print
Author Topic: Driver test and motor tuning not working  (Read 513 times)
taconick
Active Member
Offline Offline
View Profile
« on: June 12, 2010, 06:19:43 PM »
Yesterday I as doing some cutting and the machine and computer stopped communicating. I talked to the company that made the machine and they said it sounded like a mach3 issue. I tried to run a driver test and nothing happened, same thing when I tried to check the motor tuning, nothing. I reloaded mach3 and they both worked fine, I loaded the xml for my machine and tried to jog the machine in the x and y axis and it is like they are both stuck on something (z is still working) so I tried to use the driver test again. No-go same with motor tuning they don't come up no matter how many times you click on them.  I am going to reload xp on my shop computer to see if that solves the problem. Any other suggestions?
I just recieved a new gecko drive for the x because the other one got a metal shaving in it some how and blew up.  So one of the first things that I did when the axis' stopped working was make sure they were both clean and there are no problems there.
Nick Chirstensen
Little Sapling Toys
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: June 12, 2010, 06:47:14 PM »
Can you attach the xml please.
taconick
Active Member
Offline Offline
View Profile
« Reply #2 on: June 12, 2010, 09:31:05 PM »
I tried to attach the XML but it told me that there was already a file by that name on here?... Also where is the attach files button, or do you just press post after you browse for the file? Anyway, I tried to hook up the machine to another computer and still the same results. My friend helped me to figure out the driver test thing it seems that I moved the mach 3 folder instead of shortcutting it. That makes me think that I should try some other things a well.
The machine is a Romaxx HS-1 running the 300ipm XML.
Nick
manmeran
Active Member
Offline Offline
View Profile
« Reply #3 on: June 13, 2010, 01:53:28 AM »
rename your .XML to another name and then attach it
**Even a clock that does not work is right twice a day**
Pages: 1   Go Up
Print
Jump to:
