May 26, 2012, 04:49:52 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  Screen designer tips and tutorials
| | | |-+  Removing Jog Controls flyout
Pages: 1   Go Down
Print
Author Topic: Removing Jog Controls flyout  (Read 633 times)
ksangus
Active Member
Offline Offline
View Profile
« on: June 06, 2010, 08:19:42 PM »
I'm designing a very simple screen which will include the various Jog buttons, so I won't need the Jog Controls flyout, normally brought up using TAB. How do I remove it and make sure TAB does nothing to my new screen?
For more complex projects I might want to add other screens on flyouts like Jog. The Jog Controls are on screen 50 - how many screens can I have, and how do I add new ones with numbers above 15? And then how do I make them toggle with TAB, or some other key?
Keith  S. Angus
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #1 on: June 06, 2010, 09:01:47 PM »
Tab toggles screen 50. If you don't want TAB to do anything, don't use screen 50. If you want to toggle other screens, you''ll need to do it with VB code. It won't work exactly the same, though. You'd really just be changing screens, and then going back to a previous one. Screen 50 is the only one that'll flyout.
To add screens, just choose the # from a drop down list. There are 99 available.
Pages: 1   Go Up
Print
Jump to:
