Hello Guest it is June 10, 2026, 02:58:48 AM
Author Topic: Feed Hold and Stop  (Read 22577 times)
Re: Feed Hold and Stop
« Reply #10 on: June 07, 2010, 09:07:28 PM »
A point worth noting; using feedhold stops the program at the end of the line it's on within the main program. So if that line is M98 P5 L100, and p5 takes 5 minutes, you will have a long wait for it to actually stop.
No, that is not true.  FeedHold stops as quickly as it conveniently can.  It does not wait until the end of the current move.  Sometimes it will stop quickly sometimes it may take a few seconds, but it absolutely WILL stop before reaching the end of any particular move.  Try entering a long, slow move on the MDI line, or in a file, and execute it, then press FeedHold.  You'll see it does indeed stop mid-move.
« Reply #11 on: June 08, 2010, 12:06:35 AM »
There is the option in General Config, something like  "no FRO on que" which will feedhold instantly, at the expense of FRO response.
is it possible more explain about this option ?
Amir
**Even a clock that does not work is right twice a day**
