Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 04:28:25 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach Discussion
VB and the development of wizards
Frequency out
Pages:
1
Go Down
« previous
next »
Author
Topic: Frequency out (Read 640 times)
Manuel S
Active Member
Offline
Frequency out
on:
June 05, 2010, 10:22:44 AM »
Does somebody knows a way to send out a frecuency to an output?
I am trying to control an old Nd.Yag laser, and it has a device named Q-Switch. It needs to receive a variable frecuency from 500 to 20000 Hz. I tried to hook it to an axis, but the frequency must remain working to a presseted value all the time.
DaveCVI
V4 Screen Contributor
Offline
Re: Frequency out
Reply #1 on:
June 05, 2010, 08:33:32 PM »
I don't know if this will help as I've never run a laser.
There is an option in config/general config called "Set charge pump to 5KHz - laser standby".
Look in the Install & Config manual for a description of the config options.
I suspect this sets the frequency of the charge pump output to 5KHz, - you could then run that line to you laser...?
www.CalypsoVentures.com
Manuel S
Active Member
Offline
Re: Frequency out
Reply #2 on:
June 07, 2010, 08:58:52 AM »
Thanks Dave, I have tried the chargepump, but only is able to send 5Khz. or 12Khz.
I would like to be able to change it from 500Hz to 20Khz. depending on the material to be marked.
Any other idea?
Mach3 is the most easy to use and powerfull software I have tried. And maybe some new ideas will help.
Manuel S
BR549
Active Member
Offline
Re: Frequency out
Reply #3 on:
June 07, 2010, 06:05:11 PM »
Have you l;ooked at the spindle PWM output??
Manuel S
Active Member
Offline
Re: Frequency out
Reply #4 on:
June 07, 2010, 06:19:35 PM »
Yes, but I am using it as power control for the lamp.
BR549
Active Member
Offline
Re: Frequency out
Reply #5 on:
June 07, 2010, 08:06:26 PM »
OK, What is the Q-switch for???
Manuel S
Active Member
Offline
Re: Frequency out
Reply #6 on:
June 08, 2010, 07:05:15 AM »
Q-switch is an opto-acoustic device to interrupt the laser at a given frecuency, this make the laser to emit or not light.
This feature gives the laser the possibility to mark or engrave diferent materials and gives you a way to modify the color and some aspects in the laser marking.
Thanks again
renatom
Active Member
Offline
Re: Frequency out
Reply #7 on:
June 08, 2010, 07:52:59 AM »
Hi Manuel,
Do you still have a spare Analog ouput, If Yes you can buy a analog to frequency converter. I am currently using one on our Pulse Ferranti Laser. I can't remember the brand. I will check it tomorrow.
cheers
renato
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline
Briceville, TN, USA
Re: Frequency out
Reply #8 on:
June 29, 2010, 03:32:28 AM »
take a look at the PoKeys, it have several PWM output that exceed what you want in both directions........
scott
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
