May 26, 2012, 04:10:37 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Z Zero touchplate oddity...
Pages: 1   Go Down
Print
Author Topic: Z Zero touchplate oddity...  (Read 581 times)
Zaaephod
Active Member
Offline Offline
View Profile
« on: June 02, 2010, 01:18:32 PM »
Hey guys,
EDIT: Oops, forgot to mention, parallel port driven steppers, no smoothstepper. Everything else seems to be working fine.
I've been using the code below for quite a while for my Z zero touch plate. I'm not sure why, but something odd has started happening recently.
I get everything ready, click the button, the Z axis starts coming down, hits the touch plate, then shoves itself down another 1.5-2mm, then retracts to an inaccurate reading. Needless to say, that's not so good for the bit.
The problem seems to be coming from this line. If I remove the line, the downward motion doesn't happen.
Code:
Code "G0 Z" &ZProbePos 'go back to that point
I double checked, and yes, positive numbers are supposed to make the axis go up, not down. All I can guess is that it's getting a strange reading into the ZProbePos variable. I disabled my macro pump script, but that made no difference.
Any ideas?
Code:
PlayWave ("SOUNDS\AUTOZZERO.WAV")
CurrentFeed = GetOemDRO(818) 'Get the current feedrate to return to later
PlateThickness = 2.40 'GetUserDRO(2.40) 'Z-plate thickness DRO
If GetOemLed (825)=0 Then 'Check to see if the probe is already grounded or faulty
DoOEMButton (1010) 'zero the Z axis so the probe move will start from here
Code "G4 P2" ' two second delay
Code "G31 Z-80 F100" 'Z goes down a max of 20mm at 100mm/min
While IsMoving() 'wait while it happens
Wend
ZProbePos = GetVar(2002) 'get the exact point the probe was hit
While IsMoving ()
Wend
Call SetDro (2, PlateThickness) 'set the Z axis DRO to whatever is set as plate thickness
Code "G4 P0.25" 'Pause for Dro to update.
Code "G0 Z4" 'retract Z to 4 mm
Code "(Z axis is now zeroed)" 'puts this message in the status bar
Code "F" &CurrentFeed 'Returns to prior feed rate
Else
Code "(Z-Plate is grounded, check connection and try again)"
Exit Sub
End If
« Last Edit: June 02, 2010, 01:24:54 PM by Zaaephod » Logged
M250cnc
Active Member
Offline Offline
View Profile
« Reply #1 on: June 03, 2010, 04:28:22 AM »
Have you got a tool offset enabled ?
In my version of the tool zero script i turn off all offsets
Phil
Zaaephod
Active Member
Offline Offline
View Profile
« Reply #2 on: June 03, 2010, 08:54:12 AM »
I don't use them, so I shouldn't have, but I'll check when I get back. Thanks Smiley
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline Offline
View Profile
« Reply #3 on: June 03, 2010, 10:52:04 AM »
Hi Zaaephod,
Just thought I'd offer up the code that I'm using with my touchplate. It's the latest version that I know of and I haven't had any issues, and I use it ALL the time.
Obviously some of the settings may be different for you so use with caution.
Code:
CurrentAbsInc = GetOemLED(48) 'Get the current G90/G91 state
CurrentGmode = GetOemDRO(819) 'Get the current G0/G1 state
PlateThickness = GetUserDRO(1151) 'Z-plate thickness DRO
Code "G4 P2" ' this delay gives me time to get from computer to hold probe in place
Code "G90 G31Z-20 F10" 'probing move, can set the feed rate here as well as how far to move
Wend
ZProbePos = GetVar(2002) 'get the axact point the probe was hit
Code "G0 Z" &ZProbePos 'go back to that point, always a very small amount of overrun
While IsMoving ()
Wend
Code "G1 Z.250 F60" 'put the Z retract height you want here
While IsMoving ()
Wend
Else
Code "(Z-Plate is grounded, check connection and try again)" 'this goes in the status bar if aplicable
End If
If CurrentAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
End If
If CurrentGMode = 0 Then 'if G0 was in effect before then return to it
Code "G0"
End If
Exit Sub
Dave->    Wink
Darc
Active Member
Offline Offline
View Profile
« Reply #4 on: June 04, 2010, 05:33:28 PM »
I was having exactly the same problem, I added a line to zero Z axis before it started to move down, now everything works fine.
Pages: 1   Go Up
Print
Jump to:
