Hello Guest it is June 09, 2026, 07:02:29 AM
Author Topic: Nothing is moving...  (Read 13085 times)
« on: June 02, 2010, 04:33:50 AM »
hi,
I 'm newest in CNC and i have some problem : motors don't move :-\
I am setting up a 3 Axis system and am using a package from Kelinginc.net which is
5056 drivers using a C10 breakout board.
On the C10 board, I have jumpers set as follows :
__Pins 2 - 9 jumpered for output
__Pins 2 - 9 jumpered for pull down
__com jumpered for com=5V
__input pins 10 - 15 jumpered for pull down
-Pin 2 = x step  -pin 3 = x dir
-pin 4 = y step  -pin 5 = y dir
-pin 6 = z step  -pin 7 = z dir
there are no limit/home switches connected.
there is an Estop switched to Pin 10
thanks for help...
  •  9,356 9,356
Re: Nothing is moving...
« Reply #1 on: June 02, 2010, 05:53:56 AM »
Just a thought but have you tied the 'Enable' pin to +5 Volts [X8 on the C10]  (if you haven't then all output pins will be at ground potential).
« Reply #2 on: June 02, 2010, 06:36:52 AM »
yes Tweakie and that what i have as chown in the picture
« Reply #3 on: June 02, 2010, 08:08:36 AM »
and i had wired the stepper in this way :
  •  9,356 9,356
« Reply #4 on: June 02, 2010, 10:49:36 AM »
In an attempt to narrow down the problem and decide if it is software or hardware related.
Download and run Parmon http://www.geekhideout.com/parmon.shtml this will establish that Mach is configured correctly and that you can in fact write to and read from your parallel port.
« Reply #5 on: June 02, 2010, 12:18:52 PM »
I had yet downloaded parmon and all seems fine and when i try jogging motor pins change color from green to red and from red to green but there is something unusual when i used a multimiter to know parallele port voltage and it show :
pin 2 and pin 3 = 4.39v when i jog X+ and  1.86 with X-
pin 4 and pin 5 = 2.89v when i jog Y+ and  0.75 with Y-
pin 6 and pin 7 = 1.60v when i jog Z+ and  0.60 with Z-
pin 3 and pin 10 =4.40v
pin 5 and pin 10 =4.40v
pin 7 and pin 10 =4.40v
is that seems normal..!
  •  9,356 9,356
« Reply #6 on: June 03, 2010, 01:01:58 AM »
Try changing input pin jumpers (on C10) to 'pull up' and configure Mach motor outputs to 'active low'.
« Reply #7 on: June 21, 2010, 12:32:03 PM »
sorry for delay...
 hi,
tweakie i resolved the problem:
 - first i bought i new pci printer card and it carrie  5v or 0v i jogging
 - second some integrated circuit "SN74LS00" was broken so i changed and the motor finally move...
thanks for help and suggestion
  •  9,356 9,356
« Reply #8 on: June 21, 2010, 12:53:00 PM »
That's great, glad you got it all working.
