Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 03:33:49 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
SmoothStepper USB
(Moderator:
Warp9TD
SmoothStepper USB & Encoders for idiots
Pages:
1
Go Down
« previous
next »
Author
Topic: SmoothStepper USB & Encoders for idiots (Read 1859 times)
ticoe
Active Member
Offline
on:
May 29, 2010, 04:53:37 PM »
I have a 1934 Index Mill running on SolidWorks/FeatureCam/ Mach3/smoothstepper/keling c11 board/gecko servo drives/ Community gate opener 12v dc motors modified with US Digital E5 200 count rotary encoders attached to their back ends for the last year and a half with beautifully results and no problems. How I maneged this is a big question? But now I would like to add the same US Digital Rotary E5 encoders to my mill
table
, (not to the back of the motors ) and have the smooth stepper board read them on port 3 / Mach3 /settings display for manual operation. Ive played with this for four days now and Iam lost. Iam lost on the settings for the port and pins/encoder/Mpg on Mach3. The smooth stepper manual on page 20 says 1A = pin 1, 1B = pin 2, 1I = pin 3, 2a = pin 4, 2B = pin 5, 2I = pin 6 While the board itself has 11 pins and 2 are 5v and grnd. that leaves 9 pins, 3 are direct and the last six are differential. Here's where Iam lost. Can anyone decipher this for me. On the port and pins /encoder,what should the setting be?
Thank You
Ticoe@aol.com
Active Member
Offline
Carnoustie, Scotland
Re: SmoothStepper USB & Encoders for idiots
Reply #1 on:
May 29, 2010, 05:24:04 PM »
Is your encoder single ended or differential? which pins do you have the encoder connected to?
ticoe
Active Member
Offline
Reply #2 on:
May 30, 2010, 06:49:35 AM »
They are US Digitall E5 Encoders and I believe they are differential encoders, they have four connections ,a 5v ,grand, Phase A and Phase B. The Smooth Stepper board is the one that is confusing me, it has 11 pins and are labled as follows A1, B1, I1, 5V, Grnd, 2A+, 2A-, 2B+, 2B-, 2I+, 2I-. the first 3 pins are labled single ended and last six pins are labled differential . I have my encoder now connected the 5v,grnd and Phase A to connection 2A+ and Phase B connected to 2a- ? any Ideas? Thanks
Active Member
Offline
Reply #3 on:
May 30, 2010, 10:37:07 AM »
Ok well if you only have 5 pins they are single ended, differential would have 8.
You should either use the first two pins, ie Channel A of of Encoder to A1 and Channel B to B1, in Mach you would then set up the encoder to be Port 3 and Pins 1 and 2. If for some reason you want/need to use the other pins on the SmoothStepper then you would connect A of encoder to 2A+ on SS and B to 2B+ and in Mach you would set the port to 3 as before but this time use pins 4 and 5.
Active Member
Offline
Reply #4 on:
May 30, 2010, 10:40:28 AM »
Actually to add to the above you could connect to any pins on Port 3 of the SS except 2A- 2B- and 2I- as they are only used if using differential inputs from your encoder, ie your encode has A+ A- B+ B- I+ I-
And also better mention you will not need to connect the Index pulse (I) of your encoder as its not needed in your situation, I never mentioned it in the previous post.
ticoe
Active Member
Offline
Reply #5 on:
May 31, 2010, 02:34:03 PM »
Tomarow I will try and wire up the encoder as follows, Wait would you not think that the smooth stepper board would come prepared to handle three encoders X,Y and Z having 6 pins labled diferential encoders? Or is it only prepared for two encoders X and Y. going back to the begining i will try my 4 wires from the encoder to 5V,grnd,Phase A to SS board 1A and Phase B from my encoder to SS 2A+ . Hood is that what you mean?
Active Member
Offline
Reply #6 on:
May 31, 2010, 03:03:10 PM »
Yes that will work and in Mach set the encoder to Port 3 pin 1 and 2
You could input 3 encoders on Port 3 if you just had single ended encoders and were just using the A and B channels of each. The labeling on the SS is slightly misleading as you dont have to have channel A to one of the A pins, you could put it on the I pin if you wished as you would just tell Mach that channel A is connected to pin 3.
Also worth noting is you can use Port 3 pins as normal Inputs, they are not just encoder inputs.
Active Member
Offline
Reply #7 on:
May 31, 2010, 03:06:20 PM »
Oh no hang on
Just looked at SS manual and it is labeled 1A, 1B 1I 2A+ 2A- 2B+ 2B- 2I+ 2I-
So if you have A to 1 A and B to 2A+ you will need to set Mach to pin 1 for A and Pin4 for B
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
