May 26, 2012, 03:32:29 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| | |-+  Problem with Zeroing X, Y, Z after homing.
Pages: 1   Go Down
Print
Author Topic: Problem with Zeroing X, Y, Z after homing.  (Read 416 times)
SailFl
Active Member
Offline Offline
View Profile
« on: May 29, 2010, 07:09:53 AM »
I am using version R3.042.029.  Lately when I click on Ref All Home, the X, Y and Z are not set to zero after it has completed homing the system.  I do have the Auto Zero checked in the Home / SoftLimits Config page for each axis.  What could be the problem.
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #1 on: May 29, 2010, 07:21:40 AM »
Does it home correctly other than not zeroing
If no do you get a reset and/or any message in the ticker window?
If yes then make sure you dont have a home off value set for the axis.
Failing all that try disabling Auto Zero, close Mach and restart Mach then set back to Auto Zero and again shut down and restart Mach and see if that helps.
SailFl
Active Member
Offline Offline
View Profile
« Reply #2 on: May 29, 2010, 08:29:40 AM »
Hood,
The system has been correctly finding home.  I do not have any Home Off Values set.
I did what you suggested and that appears to have fixed the problem.  I will see what happens over the next few days.
Thanks for the suggestion.
Active Member
Offline Offline
View Profile
« Reply #3 on: May 29, 2010, 11:11:08 AM »
Hopefully it will stay working, if not might be an idea to try a reinstall of the version you have.
Pages: 1   Go Up
Print
Jump to:
