May 26, 2012, 03:17:43 AM
Search:     Advanced search
+  Machsupport Forum
|-+  Mach Discussion
| |-+  Mach Screens
| | |-+  How to start cycle? New to screen design
Pages: 1   Go Down
Print
Author Topic: How to start cycle? New to screen design  (Read 785 times)
system32
Active Member
Offline Offline
View Profile
« on: May 26, 2010, 01:30:41 PM »
I am new to designing screens with Mach3 and I have made an example for me to work with, but why when I select start cycle it does not go through the G-Code and on the toolpath screen does not show a simulation of whats going on. I set the button to Cycle Start/Run function but its not working. What am I doing wrong? Here is my example file.
Thank You Smiley
* example.set (1.06 KB - downloaded 98 times.)
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #1 on: May 26, 2010, 01:44:43 PM »
You have that button set to OEM 1016
Select "System Function" / RUN
"I haven't failed. I've just found 10,000 ways that won't work."         Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #2 on: May 26, 2010, 01:47:30 PM »
OEM 1016 is the "Run From Here" function.
Abe Lincoln
system32
Active Member
Offline Offline
View Profile
« Reply #3 on: May 26, 2010, 01:52:16 PM »
Thank you Smiley.
I was using the software MachScreen V1.42 and not Screen4. I selected Cycle Start in MachScreen but was not working, but working with Screen4 when set to Run. Thanks again Smiley
« Last Edit: May 26, 2010, 01:53:47 PM by system32 » Logged
Overloaded
Global Moderator
Offline Offline
View Profile
« Reply #4 on: May 26, 2010, 01:56:47 PM »
OK, then in MachScreen you would select OEM 1000.
 Smiley
Abe Lincoln
ger21
Global Moderator
Offline Offline
View Profile WWW
« Reply #5 on: May 27, 2010, 10:56:06 AM »
Do you have a reset button? You'll have to push reset before you can run code.
Pages: 1   Go Up
Print
Jump to:
