Hello Guest it is June 12, 2026, 03:03:22 AM
Author Topic: mach3 and beam saw  (Read 16252 times)
mach3 and beam saw
« on: May 23, 2010, 03:17:41 PM »
Helo!
Make old machine control exchange on a saw, Mach3 controls it and DSPMC - Ethernet Motion Controller
The problem:
a macro would be needed what does a process if it is X the value of an axis smaller than 150 mm ,
so X let an axis go onto a size there let him wait give one M9 code, and let him go to the back 200mm
I tried to do it, but since 0 are his starting values x axis, the mach does nothing at the time of a departure
Regards Csaba
Re: mach3 and beam saw
« Reply #1 on: May 25, 2010, 01:06:10 AM »
There is not a solution, please help me!
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #2 on: May 25, 2010, 09:56:31 AM »
Hi Csabika - welcome to the forum.
Can you explain again what you're trying to do? Also can you attach your macro as far as you have got please?
« Reply #3 on: May 25, 2010, 05:06:32 PM »
Hi stirling!
Remake beam saw.
The problem:
Small size the saw takes on the motive construction,
it is necessary to release the sheet after standing for a size because of this
macropump.m1s
CurrentXposition = GetOemdro(842)
If CurrentXposition <= 150 Then
code "M9"
Else
code"G90 x300"
End If
Offline stirling
  •  2,188 2,188
  • UK
« Reply #4 on: May 26, 2010, 02:47:44 AM »
Hi Csabika - Sorry but I'm still not sure what you want to do. But if I describe what your macro is doing it may help you to find a solution.
A macropump driven macro runs every 10th of a second - continually. Therefore when X<=150 it will just execute an M9 over and over again - forever - until something else (your gcode maybe?) moves X over 150. BUT - when X>150 it will execute a G90 X300 over and over again - forever - again until something else moves it less than 150. Then of course your back in the first condition - etc. etc.
Ian
« Reply #5 on: May 26, 2010, 03:28:54 PM »
Hi Ian!
Yeah! I do not know the solution because of this.Because, with the first occasion when X<150 runs down then the macro, but the machine leaves so that X=0 and the macro runs immediately already that switches it over to 300 and is frozen off there! I gave a thought to it how I put a switch onto the beam and when the motive construction is so near that the intestine of the saw would cut it X into an axis presses the switch before it and a macro runs down onto the sign of that switch then and it sends it backwards X axis.
thanks!
Csaba
Offline stirling
  •  2,188 2,188
  • UK
« Reply #6 on: May 27, 2010, 10:13:11 AM »
Csabika - can you attach your gcode file please?
Ian
« Reply #7 on: May 27, 2010, 11:48:46 AM »
Hi Stirling!
A code detail, a board starts his length:
M3
g0 x2000
m7
m8g04p2
y1500
m9g04p2y0
x800
m7
m8g04p3
y1500
m9g04p2y0
m5
y0
M3
g0 x100
m7
m8g04p2
y1500
m9g04p2y0
It M codes control valves
csabika
Offline stirling
  •  2,188 2,188
  • UK
« Reply #8 on: May 28, 2010, 02:39:28 AM »
Hi csabika - maybe I'm missing the point - but I can't see why you need a macro at all and certainly not a macropump. Your gcode is completely predictable (as is gcode generally) so you KNOW where it's going to be at any time. You don't need to say "IF X < anything" because you commanded it to be there. Just write your gcode to do whatever it is you want with your saw and it will do it.
FWIW - you need to command a Feedrate and use G1 for your cuts. At the moment you are cutting at RAPID (G0) speed - generally not good practice.
Hope this helps - Ian
« Reply #9 on: May 28, 2010, 01:07:21 PM »
Hi Stirling!
I make!
for me a problem ,
If the size is small, A saw cuts into iron
I turned up output1 let an be a pliers, and made macropump
if input gives a sign, releases it the pliers, and an axis goes to the back 200mm
