Hello Guest it is June 11, 2026, 03:22:48 AM
Author Topic: Mach3 Language  (Read 18080 times)
Mach3 Language
« on: May 22, 2010, 10:37:39 AM »
Hi to all
I just acquired Mach3 from a German company.
Because that I have some newbie questions.
I already find out that changing the screen I can make it to be in English, but the upper menus still in German.
1. Is there any way to make the entire Mach3 to be in English?
2. I have a tool height sensor but don't know how to make it work. Is any configuration required?
The sensor is this one http://www.bzt-cnc.com/product_info.php/info/p397_BZT-Tool-PushbuttonTool-Length-Compensation.html/XTCsid/1b654dace520fde4f5c7cf924d777c68
3. I'm also trying to implement cycles - call another NC/Tap file - but it's not working...
Is there something worn with this code?
M00
G56
G51 X1.0000 Y1.0000 Z1.0000
M98 (PGM\G54_FLAT8_L75.nc)
M00
G57
G51 X1.0000 -Y1.0000 Z1.0000
M98 (PGM\G55_FLAT8_L75.nc)
M5
M9
M30
also tried with absolute paths but still don't wok.
Any help will be appreciated.
Re: Mach3 Language
« Reply #1 on: May 22, 2010, 11:08:23 AM »
Have you tried downloading it from here?
Re: Mach3 Language
« Reply #2 on: May 23, 2010, 06:00:58 PM »
It does not work here either. The remote call does not work AND it does not work if you call it from the sub directory either.
1 it does not allow calls except from the sub directory
2 Even then it does not work with a M99 return, you get error "Return call with no sub in effect"
3 nor will it work with no M99 as it will not return to the main.
Just a thought
Re: Mach3 Language
« Reply #3 on: May 24, 2010, 02:47:09 AM »
Yes I tried. It appears that it doesn't read the licence from the german version, because only works as demo.
??? So it works or not?
So the beahovior should be M98 (G54_FLAT8_L75.nc) instead of M98 (PGM\G54_FLAT8_L75.nc). Tried... not work
So the file G54_FLAT8_L75.nc should have a M99 at the end? Also tried that. Still not work.
Re: Mach3 Language
« Reply #4 on: May 24, 2010, 10:40:08 PM »
IT appears broken the only way I can call the sub is for the sub to be IN the sub directory AND not have a m99 to return. BUT then it will never return to the main program so it appears broken.
Sorry
