Hello Guest it is June 09, 2026, 04:05:51 PM
Author Topic: Activating a solenoid using Mach 3  (Read 9976 times)
« on: May 21, 2010, 02:08:42 PM »
Hello,
Iam building a DIY CNC embroidery machine, and where are jump stitches
(bigger than 10mm x example) I need to activate a command
to release thread tension, preventing needle bending, thread breakage
or fabric deformation.
This command will activate a 12 volts solenoid (from car door)
who pull a pin in thread tensioner and release thread.
I neet to set a 5vd input relay / out put 12vdc, Any sugestion?
How can I configure Mach and controller connection for this?
Thanks in advance
Rene
Re: Activating a solenoid using Mach 3
« Reply #1 on: May 21, 2010, 02:48:32 PM »
please see schematic.
use TIP122 for transistor.
**Even a clock that does not work is right twice a day**
« Reply #2 on: May 24, 2010, 11:17:49 AM »
I made my own Solid state relay for high current devices (a big solenoid coincidentally);
but for run-of-the-mill stuff I have several of these little guys:
http://www.cnc4pc.com/Store/osc/product_info.php?cPath=24&products_id=133
Solid state. Fast, silent, work great with MACH. For 8 bucks, it's not worth getting out the soldering iron . .
Just watch your current draw and make sure you use something that can handle it.
They have a nice selection of BOBs as well. I use their C1G . . .  love the status LEDs on each pin!
« Last Edit: May 24, 2010, 11:27:29 AM by simpson36 »
« Reply #3 on: May 24, 2010, 11:45:32 AM »
Hello Simpson, thanks
« Reply #4 on: August 15, 2011, 11:10:20 AM »
Hello
Im planning to move a 24DC motor in a new CNC Project.
I have a Hobby CNC pro controller and a C9 DC Solid State Relay from CNC4PC capable to drive from 6-60dcvolts motor and 10 A.
My plan is connect Relay to Pin 1 in CNC Controller, and activate in this way,
My question is.
Is necessary to connect some device between  Pin 1 and  5VDC  Relay connector?
Thanks in advance.
Rene
