Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portugese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 26, 2012, 02:40:02 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Mach3 and G-Rex
Setting scale to a permanent setting
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Setting scale to a permanent setting (Read 1251 times)
LarryL
Active Member
Offline
on:
May 19, 2010, 11:27:09 AM »
Hi all,
Is it possible to set the scale in Mach3 to a permanent setting? I have found that my CNC quilter using Mach3 is calibrated to 1inch=0.0478 on the DROs. By manually setting the scale to 0.0478, my files reproduce to exactly 1 inch scale. Can I make this permanent?
Larry
Overloaded
Global Moderator
Offline
Re: Setting scale to a permanent setting
Reply #1 on:
May 19, 2010, 12:00:52 PM »
Hi Larry,
You can put this little script in a macro, then put the macro in the initialization string to run on a reset.
The dro will then be set everytime you start up.
Hope this is what you want. Other axis's can be done the same way.
Russ
"I haven't failed. I've just found 10,000 ways that won't work." Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
ger21
Global Moderator
Offline
Reply #2 on:
May 19, 2010, 07:42:37 PM »
Can't you just change the steps/unit?
http://home.comcast.net/~cncwoodworker/2010.html
Overloaded
Global Moderator
Offline
Reply #3 on:
May 19, 2010, 07:52:19 PM »
......my initial thought as well Gerry, just figured I'd try to answer the puzzling question.
Perhaps the machine is set up correctly and the files are scaled. Might want to leave the machine true for other 1:1 projects.
Hope Larry comes back with more info.
Abe Lincoln
Overloaded
Global Moderator
Offline
Reply #4 on:
May 19, 2010, 07:57:01 PM »
then again, he did say PERMANENT......didn't he.
Abe Lincoln
LarryL
Active Member
Offline
Reply #5 on:
May 20, 2010, 01:49:08 AM »
Quote from: ger21 on May 19, 2010, 07:42:37 PM
Gerry,
While it is possible to set the steps/unit for the quilter, this doesn't take into account the size of the pulley on the motor. Basically, what I am trying to do is compensate for that issue. By setting the scale to 0.0478, it calibrates the system so that the output movement is exactly one inch. My problem is that I am in Germany, and I have difficulty procuring the parts necessary to do the job correctly. I am forced to use a work around by re-calibrating the system mathmatically.
Like Overloaded said, it is to be permanent.
Larry
Overloaded
Global Moderator
Offline
Reply #6 on:
May 20, 2010, 06:44:38 AM »
Larry,
The steps/unit is setable for the purpose of compensating for pulleys and other drive line components/configurations, you should not have to change any hardware.
I'm confused......would you describe you axis drive in detail ?
Pulleys, # of teeth, screws, linear belts, rack/pinion, ratios, etc ... ? ? ? ? ?
I might be missing the obvious but this looks too easy to fix by simply adjusting the steps per as Gerry mentioned.
Abe Lincoln
LarryL
Active Member
Offline
Reply #7 on:
May 20, 2010, 08:20:27 AM »
Russ,
I'll have to get back to you later this evening. I am at work right now and don't have my notebook in front of me.
ger21
Global Moderator
Offline
Reply #8 on:
May 20, 2010, 06:23:25 PM »
All your doing by changing the scale, is adjusting the steps per unit.
For example, if your steps per unit is 100, changing it to 50 is the same as setting the scale to .5.
LarryL
Active Member
Offline
Reply #9 on:
May 23, 2010, 03:51:00 AM »
Russ, Ger,
Russ, in answer to your inquiry about the type of axis drives that I am using. This is a very straight forward belt drive that has two motors. The x-axis is approximately 12 feet long and is a 1/4 inch open ended timing belt with 22 teeth per inch the pully is 9 mm in diameter with a 14mm shoulder and an external locking hub. The y-axis is the same except for length. It is 24 inches in length. The axis pulls the carriage for the sewing machine in accordance with the instructions in the gcode file. The problem that I was having with the scale was very simple, every time I tried to run the system on a file of a given length, i.e. 1 inch, the pattern would sew 13 inches, so basically a 13:1 increase. The cure was simple, scale it to a setting that would equal 1:1. The quilter uses basically the same technology as a milling machine, except it doesn't cut a billit or block of wood, it simply pulls the carriage with the sewing machine on it. The sewing machine is the real work horse. It has a stitch length control attached at the pedal port which keeps the length of the stitch constant no matter what the speed is. Now, here is where the problems start. Most of the patterns that I have were downloaded from a commercial site, they are made, for the most part, for long arm quilting machines, these machines have a working area of anywhere from 8 inches high and 16 inches long to over 24 inches long. My machine has a working area of approximately 6 x 9 inches, hence, pattern adjustment is necessary to keep the machine from trying to go outside the working area. Take a look at the photos that I uploaded, and you can see what I mean. There are no compound pulley systems on the machine. Each pulley does one thing, it pulls along it's own axis, kind of like a cog-wheel train on a gear track.
Ger,
You mention that all I am doing is adjusting the steps per unit. Well, I only needed to do just that, but on a permanent basis. I wanted mach3 to present me with the proper scale that would give me one inch of travel when I told it to. The macro that Russ gave me works perfectly, the settings are now present when I turn on the system and it works great.
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Quantum
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Wizards
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
