Hello Guest it is June 12, 2026, 08:18:54 PM
Author Topic: my motor speed - RPM is changing, why?  (Read 6874 times)
« on: May 10, 2010, 02:39:10 PM »
Hello, I met a problem here
when I use button jog mode with 100% jog rate, the motors are running much faster than I input "G1 X20 Y20 Z20", why and where I can setup it?
thanks for any help
Re: my motor speed - RPM is changing, why?
« Reply #1 on: May 10, 2010, 02:44:24 PM »
When U use G1 that means linear interpolation @ last feed or current feed rate the jog feed doesn't effect the Gcode feeds
Adam
